WhiteBeard rebuilds his carbs
Started by WhiteBeard, March 10, 2013, 11:05:51 AM
Quote from: FJmonkey on March 10, 2013, 09:32:36 PM
Quote from: movenon on March 10, 2013, 09:29:46 PM
There you go stealing stuff.... :yahoo: :yahoo:
Well... I told him I would buy him a $100 beer at the WCR....  :rofl:
Sounds like a good deal to me. I am looking forward to the rally.... Looks like the OZ team had a good run of it from there photo's.
WhiteBeard
Okay, the carb bodies were divided like so...
I needed an impact wrench to get some of the screws on the alignment brackets out, even with brand new carbs.
Phew...
But I came across a problem when it came to removing the float hinge pins, they are really stuck in there. Really.
I find this strange, I had no problem removing the pins from my 28 year old carbs. And I'm afraid of using too much force on those aluminum posts in case they brake.
If I get the time, maybe I will go and buy a heat gun and see if some heat will help.  :sorry:
Just use a small drift and drive only on the pin. Make sure the punch is not tapered ot the stantion can be broken.
There a small shoulder at the head end of the pin that are tight on new carbs.
JMR
A friend of mine in Georgia welds broken float posts. Works mint. :yes:
WhiteBeard
Quote from: racerrad8 on March 11, 2013, 10:30:00 AM
Okay, I'll continue trying.
Thanks Randy.
/Nat
keand3
Thanks! Just what i wanted to see :good2:
WhiteBeard
So I managed to remove the float pin using an automatic center punch, worked just like it should!
Also got the carb tops off, except for one screw that is giving me a really hard time...  :mad:
Shit, those screws are tight AND soft! And since I didn't get the proper JIS screwdrivers I manage to mess the head up good and proper.
Tried making a slot for a flathead screwdriver, but the screw melts under my fingers.
With the help of a vise grip I got the other ones out, but this one keeps slipping. My next strategy is filing the sides down so the locking pliers get a better grip.
And of course I managed to slip on another screw and make a dent in the carburetor top.
Hopefully nothing serious...  :blush:
On another note, I have jetted the carburetors with Mikuni 40.0 pilots and 112.5 main jets supplied by Randy. I will be using Dual Pods and stock exhaust to begin with.
Do I need to get a set of adjustable main jet needles from RPM and shim my needles?
Also, I just got these back from the ceramic coater:
So later I will also be using a Supertrapp 4-1 together with the Dual Pods. Would this warrant another change of jets?
Sorry for the newbie questions...   :hi:
Nat
I had one like that too. Seem to make a big difference when I put a shifter, tight and directly on the jaws of the vice grip. I think It eliminates the torque going through the vice grip fulcrum point, so minimising.....nahh..I don`t know why it worked..just did? (and yes I was originally turning the jaws preciseley square to the screw axis).
^^^ ok, need a wee bit of help here...what the fuck did he just say....?  Damn convicts.
shifter
The first pint of beer consumed after a work shift is over, usually sold at a fraction of the price of a regular pint.  :hang1: :hang1: :hang1: :scratch_one-s_head: :scratch_one-s_head: :scratch_one-s_head: ???
Quote from: movenon on March 13, 2013, 07:09:12 PM
shifter
Shifter..An adjustable wrench on which you can shift the size of the jaws.--don`t get wrench mixed up with wench (no adjustment on the jaws and can damage nuts.)
Ok, got it. You bite the soft head, then use a wench to turn the screw.....makes perfect sense...thx Doug.
OH, an FJmonkey wrench ! oops just a "monkey" wrench !  I think the pint or maybe two would also help....  :yahoo:
WhiteBeard
Quote from: WhiteBeard on March 13, 2013, 04:00:34 PM
Later on I will also be using a Supertrapp 4-1 together with the Dual Pods. Would this warrant another change of jets?
Randy is guiding me through this one, so everything is good!  :good2:
