My Status
Started by Lotsokids, March 08, 2013, 12:20:02 AM
my thoughts are with you mate, glad your going to have the help you need and deserve, think if you had stayed in hungary ,the operations would of been like they're  car modification rules , cant fix you as they dont have the original bits
Lotsokids
Quote from: racerman_27410 on March 29, 2013, 10:33:02 PM
Did Pam and the kids come with you?
No, I came alone.
Thanks again everyone for the kind words.
baldy3853
Steve_in_Florida
Quote from: Lotsokids on March 29, 2013, 10:06:19 PM
They want to do everything including the corrective surgery which requires transplant of a bone from my leg.
This procedure is REALLY gonna mess up the status quo:
"...the foot bone connected to the leg bone. The leg bone connected to the CHIN bone..."
:wacko3:
You're a "one-off" dude, for certain.
I've heard really good things about Mayo care, though. My healing thoughts are going your way, too. With all this virtual karma, and the grace from above, you're going to be O.K.
`90 FJ-1200
`92 FJ-1200
IBA # 54823
Lotsokids
Getting a little nervous. I now have a "recent" blood clot, probably from the flight over here. On Apr. 17, they will install a filter into my vein (center body) through the groin. Yes, while I'm awake, but on slight anesthesia through an IV. Then the following day on Apr. 18 is the major surgery. Unfortunately, they will need to do a tracheotomy and feeding tube again. But I'm sure those will be more pleasant than when I had those in Hungary! The doctor assured me I would not wake up in a room shared with 5 old men in diapers. YAY!
I'm kind of concerned about having blood clots going into surgery. I need to stop taking my blood thinners 3 days prior to the surgery. After surgery bed-rest is a breeding ground for blood clots. Hard to be active with a bone removed from the leg.
I feel like I'm throwing myself into their hands in complete faith. Compared to my options, that's fine. All the doctors I have met here are very talented, confident, calm, and reassuring.
You have made it this far man, finish out your E ticket ride and let the powers that be take care of the rest. Thank you for being you....
Many prayers going up for you Mark....  :good2:
Hang in there brother.
Sending my prayers and good thoughts your way Mark. Thanks for checking in. It's gonna be ok. Pat
youll get to wear those funky anti blood clot stockings, with any luck you should have a private room
Bummer you being by yourself. Some of the exercises they`ll give you are the same as riding the FJ - like clutch and front brake movements for the hands and gear change and/or rear break (depending if leg is still incapacitated)- make sure you keep doing them.  I found a set of DR handlebars with tennis balls jammed under the levers really good- but the guys in diapers didn`t appreciate the sounds...mainly cause I kept the imaginary tacho constantly in the red range!...great for coming out of the corners...but not if the meal tray is still there... :dash2:
Quote from: fj11.5 on April 07, 2013, 11:40:24 PM
Hey mate, I kept mine.  :gamer: They use warm air to pass through their internal tubes. I plan to work out a way to pass warm water through them when on tha finger freeze ride. I reckon if I hooked`em up to the old oil cooler (that`s gettin replaced by Randy`s) then a couple of tubes, cable tied near me leg positions with two little taps to control temperature via waterflow.
Instead of anything fancy like an electric pump, I was thinking of a small bellows, operated manually...and, and and because they are flat (before they wrap around ya legs to look like stockings), you could fit one inside ya jacket, if need be!... not sure how to operate tha bellows but open to suggestions. (just remember I`m a tight arse!  :diablo:)...yet ta figure out how ta stop me fingers from freezing...practically that is!  (popcorn)
oh you had the fancy up,market items,, i had the plain old, white long sock type of stockings ,, but i like the use you have planned, , must get bloody cold over your way, i used all manner of bulky arse winter gloves, alpinestars, dryrider, ect ect,  but found the best to use are summer gloves, the leather non vented type and oxford mark2 heated grips,  weird i know, but having small hands dousnt help with winter gloves
Doug,
Don't worry about the (ex) oil cooler, just hook the tubing up to a modified condom and keep pissing into it.  That'll keep your feet warm.  Then you can heat your hands by holding them at the vents in the sidecovers.  Steering may be a bit of a problem. :-)
Quote from: Arnie on April 08, 2013, 03:13:10 AM
Doug,
Ummm...not such a silly idea! I had thought of making something like that for the snowy trip. I too have been watchen my weight. When travelling I`ve found that I put on weight everytime I stop for a leak. I found it really difficult to relieve myself when driving long distances in a car, so I knew I had no chance on a bike....until now! What about the last section of tubing...Do I need a baffle & a filter? or should I somehow recycle it?
yamaha fj rider
Our/my thoughts and prayers are with you. Everything is going to be ok, they will fix you up good as new and you will be back on two wheels before you know it.
Blessings to you and your family. Here is to a speedy recovery. Thanks for letting us know how you are doing.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
WR250F
