Anti-Dive Out.
Started by Woodsman, March 02, 2013, 08:05:42 AM
Woodsman
Probably not too many of us still around with the ad. I have just rebuilt all my original calipers in the hope that i can get the brakes to offer somewhat reasonable stopping power. Have steel lines and will fit EBC HH up front, should be ok after that.
Have decided to try it without the ad and see how it is. My question is what bolts do i require to fill the hole in the ad unit(pitch,size,not sure?).The single banjo bolt will be moved to the brake line. Tried a couple of small places with no joy. Would help if i knew exactly what i was looking for. Thanks, Sean.
"Man who chops his own wood heats himself twice"
87 fj1200,TBS,Daytona 900,NC30.
Tiger
 :hi: Hey Sean, a week or so ago I removed the brake lines and blocked off the A D from my '85. I used a couple of new flange bolts...you need: M10-1.25 x 20mm... :good2:
John.
Woodsman
Ok, thanks for that John. Did you notice much difference in the bike when the ad was gone?
If you are disabling the AD, you need a proper block-off plate to allow the fluid to flow between the two sections.  Simply filling the holes will not allow for proper fork action.  I think Randy sells such a thing, for not all that much money, IIRC.
Edit, I stand corrected, Randy does not sell these, I just checked his site.  But there are some on eBay:
http://www.ebay.ca/itm/300835303243;jsessionid=D074C9B093DE97AB718013CCD2D37F32?ru=http%3A%2F%2Fwww.ebay.ca%2Fsch%2Fi.html%3F_sacat%3D0%26_from%3DR40%26_nkw%3D300835303243%26_rdc%3D1
Woodsman
Will check out RPM. Was hoping to keep the budget down and just pop a bolt in there.
Woodsman
Thanks Dan, thought there was some crowd in Germany selling them also? Will try to find the link for it.
Just remove the top portion of the AD units and the hoses, that is all you have to do. Just need a few shorter banjo bolts where you took off the extra hoses and your budget is safe. That is how Randy did it on his 86', simple, easy and cost effective.
yep, what monkey said,, just take the top anti d hose off the unit,  should be able to use those banjo bolts on the calipers,  pretty sure its the two i used when i disabled the ad on my 84 ambulance
Woodsman
So it can be done on the cheap by removing the line to ad and block with suitable bolt or remove line and top portion of ad unit?
Is it a bolt again that's required if top portion is binned?
use a bolt if you want, but i just left these open, nothing to lose,  or fall apart, just take the hose off, and change the banjo on the caliper, bleed the brakes and go
Tiger
Quote from: Woodsman on March 02, 2013, 08:23:37 AM
:hi: I'm still up over my a$$ in snow at the minute, so no test rides :mad: However, I'll let you know come spring :rofl: :rofl2:... :biggrin:
John.
