Finally got a start!!!
Started by Tiger, February 03, 2013, 07:41:44 AM
Tiger
 :hi: How she looked before I started pulling her apart...
http://fjowners.com/gallery/4/2617_18_02_13_3_17_31.jpeg
...the original front fender is white and will be reinstalled when I fix the screw installation lugs.
The picture is from a wee Ontario FJ meet/ride in 2012...and looking forward to a lot more this season :good2:
John.
Tiger
 :hi: Another job done... :good:
The clutch lever has always seemed rather stiff/heavy since a picked up my FJ...so I decided that, having replaced the '85 master cylinder with one from a later 1200 model and replaced the clutch line with a Stainless Steel braided line back in the late summer/fall of last year, it was time to rebuild the clutch slave cylinder :good:
I drained the complete system of fluid to start and wiped out the master cylinder. S S line disconnected and the three jis hex head cap screws removed, enabled me to put the slave cylinder on the bench for strip down. I fired up the compressor to blow the piston out...but the wee bugger initially refused to move :mad: After a few shots of air it finally came free!!! Ha, whos ya daddy eh :rofl2: :lol: :rofl:... :biggrin:
NOTE: Keep fingers out of the way!!! :blush:
The old seals/spring were removed and the housing/piston were cleaned off in the parts washer and blow dried.
New seals and spring were now installed, popped back in to the housing, (which I had filled with fresh fluid)
and refitted to the engine.
Reinstalled the clutch line, filled up the master cylinder with fresh fluid and bled the system off with no issues... :good2:
Clutch certainly feels a lot better... :yahoo:
:shout: NEEEEXT :drinks:
John.
Tiger
 :hi: Slowly but surely I'm getting the work done, so that the old girl will be more than ready for the up and coming season...After all, I have to put back some of the love that's been removed from her over the years by previous owners eh!!! :biggrin:
The Krauser side bag and Givi top box rack were removed completely. They are to be mod'd slightly and painted before re-installation.
I removed the rear wheel, which needs the tire, bearings, etc removed before it gets a complete clean and repaint, as per the front wheel.
The brake caliper was removed, cleaned, serviced and new pads installed. I also fitted a Red Stainless Steel braided brake line and bled the system off...(it matches the front brake and clutch lines!!)  :good2:
The rear brake arm (swing arm to brake caliper) was removed, the old pitted black paint cleaned off, eye ends repainted and a length of black heat shrink fitted over the length of the arm. Once reinstalled, with new hardware, I gave it a coat of an Armour all type product :good:
The rear axle, spacers, chain adjusters, etc, all went in to the parts washer for a good wash and blow dry...then an extra clean up using the wire brush on the pedestal grinder. The rear chain sprocket and carrier also went for a bath and blow dry... :good:
The swing arm and underside of the rear fender needed a good clean up with an industrial cleaner...especially the left side of the swing arm which was covered in a thick abrasive sling off gunge, that I needed to take a scraper to first!!! All shite and Briney now :good:
The chain will get a kerosene bath at some point... :scratch_one-s_head:
More to come... :morning2: (popcorn)
John.
Tiger
 :hi: Nothing completed with the FJ over the weekend due to other commitments. However, I have got one or two things done since the last posting... :good:
I decided that the bearing in the rear hub clutch, (bearing #6305ZZ), wasn't 100%...and for the princely some of $8.00 I picked up a new NTN bearing from Applied Industrial Technologies, an American company with branches across North America...so, new bearing, new seal and wheel collar now installed... :good2:
Rear tire was removed from the wheel and has, along with the front one, been sent to the parts loft!!
The bearings in the rear wheel were proving to be a PITA to remove...until I borrowed a bearing removal tool from a good friend of mine and then...VOILA...out they came :good: Now I just need to give the wheel a good scrub in the parts washer to get all the grime and gunge off, let it warm up in the furnace room for a few days and repaint it as per the front wheel... (popcorn)
As I have come this far, I think I will change out the chain and sprockets. They don't look bad, but... :scratch_one-s_head:
Tiger's '85 FJ saga continues...stay tuned... :lol: :rofl: :rofl2:... :biggrin:
John.
In my experience the hub bearing is the one that usually wears out first most likely because that's where a lot of stress is and water can get in there at times. I just converted to a 5.5 GSXR rear wheel and replaced that bearing with a double sealed bearing and put a new double lipped seal outer seal in. And I know better than to point a high pressure sprayer in that area.
Also as a note any of those sealed bearings with the black plastic seal. The seal can be pulled out with a pick for re-lubing or adding lube. A lot of bearing suppliers will stock the double sealed bearing because they can allways just pull the seals or just one side to meet the customer needs.
Tiger
 :hi: Hi George...I like the fact that I can re-lube wheel bearings, periodically, by removing/reinstalling the black plastic shields, which I have done on occasion... :good:
Quite honestly, other than the hub bearing, I could have left the front/back wheel bearings for another time. However, it was cheap insurance to do them now...'pay me now or pay me later' syndrom springs to mind... :good2:
With all the new bearings in the wheels/hub, I should be able to 'coast' for miles and miles eh :lol: :rofl: :rofl2:... :biggrin:
John.
Tiger
 :hi: New DID '0' ring chain on order along with F/R sprockets...should have them for the weekend :good2:
John.
Tiger
 :hi: The saga continues...
The rear wheel, (with the tire, tubeless valve, bearings, etc removed), was dumped in the parts washer and given a good soak and scrub to remove all and any grease, grime, rubber, etc. Once I was satisfied it was well and truly clean, out it came for a wipe down and a blow dry... :good:
Repainted the rim and rotor centre, rear caliper mount arm, Satin Black and left to dry for a wee while... :good:
New wheel bearings and seal installed... :good:
New tire installed as was the rotor...all screws torqued as per the manual... :good:
Newly mounted (38t) rear sprocket and hub, (with new bearing and seal), installed in the wheel... :good:
New chain attached to the old one and led through...(old chain wrapped, packed and gone!!!)...just awaiting the new (18t) front sprocket to arrive (Monday/Tuesday) and I can reinstall the rear wheel and tighten it all back up again... :good2:
Ahhhh, spring is in the air... :yahoo:
John.
Tiger
 :yahoo: New front sprocket arrived tonight...guess wot I'm doin' this weekend :scratch_one-s_head: :rofl: :lol: :rofl2:... :biggrin:
Rear wheel is installed but not buttoned up...new chain is lead through and hangin' loose :good:
John.
Tiger
 :hi: Picked up my newly recovered Corbin saddle from a local('ish) shop. The old guy has done a grand job, just grand :good2:
Now were they hell is that big ass socket for the front sprocket I wonder :scratch_one-s_head:
John.
i could lend you my socket but cant throw it that far, , likely to drop in the pond
Quote from: Tiger on March 16, 2013, 06:06:01 PM
John.
socket is 36mm or 1 1/2" will work fine...
A tip on front sprocket removal picked up from another posting: Take your 36mm or 1 1/2 " socket and grind down the socket edge about 1/8 " or so. The large socket tapers off at the entrance point and its hard to get a good bite on the shallow drive sprocket nut. Take a look at the end of your socket and you will see what I am referring to. I used a disk sander and jammed the socket in to grind it down.. Socket works better now. FJ front sprocket Torque spec is 61 ft lb..
Tiger
 :hi: Thank you kindly for the info' George, much appreciate the input :good2:
fj11.5...Can't you get one of them there Tazzy Devil things, that spin at a grand lick, to whip one over here :scratch_one-s_head: 'course, getting it back might be a bit of a bugger though  :lol: :rofl2: :rofl:... :biggrin:
John.
could mate, but knowing the devils up here they'd bloody eat it, ,better off getting a wallaby to bounce one over  :biggrin:
rod
Quote from: movenon on February 04, 2013, 09:09:35 AM
You have to be aware that when things are apart that there is an overwhelming desire to polish shit..
One of the funniest (and truest) things I have read on this forum George,  :lol: :lol:,   you made my day, lol!!!!!!!!
