flat bar conversion
Started by fj1200owl, January 28, 2013, 07:02:02 AM
sam95
Quote from: Motorheaddad on December 22, 2013, 09:45:03 AM
Ok, don't really want to bore my yokes or do a fork swap at this time. I just wanted to know what years XJ600 I can use for a flat bar conversion. I found a 94 upper and lower triple/yoke. Will that work? The price is perfect and want to jump on it. Thanks in advance.
Hello,
Did you make handlebar conversion with XJ600 diversion 1994 upper triple yoke ? Or is it only the new XJ6 upper triple yoke which works without modifications ?
The restauration of my side car: http://www.sam95.fr/?cat=5
Some mod on my FJ: http://www.sam95.fr/?cat=16
sam95
I know those solutions, but I am looking for something less expensive if possible.
Motorheaddad
No, I just ended up drilling my top yoke and installed risers. That will work for now till I find something a bit "cleaner". It doesn't look bad but it doesn't look good either.
sam95
Can you post a photo of what it looks like ?
scotiafj
Quote from: movenon on February 08, 2013, 09:32:34 AM
They look real good :)  Ummmm off to e bay :)
Thats the top yoke Im using on my fj 12.thought it would be a straight fit but I'll need to use a spacer or some thick washers below it as it nips up the steering when the centre nut is tightened up and makes it hard to turn the bars ..did you get that problem too ??
