RPM fork valve installation??
Started by gripit_N_ripit, January 22, 2013, 07:24:49 PM
gripit_N_ripit
okay guys I know Im supposed to have a repair manual to refer to but I do not.... I am installing the RPM fork valves.... My only question is Do I have to remove to Damper rod to install the valves?? Thanks in advance.
Curtis
Quote from: gripit_N_ripit on January 22, 2013, 07:24:49 PM
Did instructions come with it? The D-Rod needs to be cut and re used to help adjust the pre-load. About 2 inches from the top to do the job. Or am I off the mark?
No, the damper rod needs to be properly adjusted. Then the damper rod adjusting rod "D" shaped needs to be cut off. Please do not confuse the two parts as they have similar names.
After you adjust the damper rod all you have brown do is drip in the valves and continue the install.
I just want to confirm you did receive instructions.
Quote from: racerrad8 on January 22, 2013, 07:41:59 PM
You mean the damper setting? Small, Medium, Large hole setting??? That would be different. Thanks for jumping in Randy. Set the man straight. Set the dampener first then cut the rod. Or do what I did and pull both forks apart and verify proper setting before completion, don't ask. It was a bitch doing it twice.
gripit_N_ripit
Thanks. Yes, Randy I did receive the instructions. Being my first set of forks Ive ever taken apart I guess Im learning the hard way... OK so for clarification the "D" rod is the adjustment rod which is part of the fork cap correct? How is the damper rod (in the bottom of the fork)  adjusted?
Curtis
By the long "D" shaped rod which runs from the top cap down into the adjuster mechanism on the damper rod..
Try looking at an exploded view to familiarize yourself
baldy3853
Just so that I get this right its the long shaft that needs to be trimmed 2"?? If not can U post a picture of the piece that needs to be trimmed??
I'm yet to buy the valves, but my understanding is the d rod needs to be cut down to 2" from the underside of the fork cap/ bottom of the preload adjuster
The later model Fj1200 don't have the D-shaped rod that needs to be cut.
My 1991 didn't require this mod.
So, if you had a pre-91 and installed the valves, could you then swap to the 91+ fork caps, so that you no longer had a not-attached adjuster atop the forks?
gripit_N_ripit
Quote from: 1tinindian on January 23, 2013, 07:07:28 AM
Whew... I thought I was loosing my marbles. So, I don't need to need to cut anything... Hey Leon I read in your post about this mod and decided to make the damper rod holding tool by filing out the inside if a nut that measured 27mm OD exactly, but the tool is slightly too small to grab ahold of the top of the damper rod. Ill try a different size nut and do it again but my assumption is that the PO or dealership may have wallowed out the teeth on the damper rod. Last question; so, if 91+ fj1200's dont have a "D" rod then the damper rod cannot be adjusted and does not need to be removed at all for this mod?? Thanks guys for chiming in. Youve been very helpful.
Curtis
This is why it's important to state the year of your FJ whenever you ask a question.  Otherwise you can (will) get bombarded by a bunch of conflicting information that may not apply to your model.
The '91+ models did not have adjustable damping.  Therefore, they don't have the damping adjuster "D" rod or the mechanism on the top of the damper rod to make the adjustment.
If you're not replacing the fork seals then you do not need to remove the damper rod for installation of RPM valves.  They simply sit on the top of the damper rod where the spring holds them in place. Use a grabber tool to place them on the damper rod.
gripit_N_ripit
My apologies David.I know better than that! :dash1: THank you for the help! Onward with the project!! :yes:
Curtis
if you have a spare rear axle nut,  that will fit your fork caps, , i had used a 27mm nut from a bolt store with a 1/2" drive socket welded on,  but my little man( 4.5 yr old)  borrowed it    :cray: so i used a spare rear wheel nut,  with an old 12mm / 12" drive socked welded to the castilated side,
