Carrillo A beams
Started by JMR, January 22, 2013, 12:45:36 PM
JMR
Noticed this special on the Orient site. These rods are light......I have them in my engine. They need some simple clearancing.
http://www.orientexpress.com/p-7265-carrillo-industries-connecting-rods.aspx
Havoc
Hey man, I'm using the H section which also required a small bit of the crank case to be shaved to clear the big end bolts. Do you know the differences in spec between the A's and the H's? Cheers Tom
Dangerous Brothers Racing
Here's the weight differences (I saved in the Files section) courtesy of Randy at RPM.
I looked at the A beams when RPM did my 1350 engine but at that time, the lead time was 4 months (and $$), so I went with the XJ rods.
For your turbo application, the H beams are the strongest....the best you can buy.
Quote from: racerrad8 on October 16, 2010, 06:00:44 PM
FJ1100/1200 rod weight =  396
XJ1250 Rod weight =  361
Carrillo A Beam =     337
Carrillo H beam =     356
Havoc
Anyone know at what power level the XJR rods should be replaced for reliability?
JMR
Quote from: Pat Conlon on January 22, 2013, 01:30:20 PM
I had to wait for mine. At least I have a dealer account with APE. Orient must have these in stock. I'd say they are good for 300Hp at least. H beams I have personally seen on 650Hp busa's.
