Buying New FZR Rotors
Started by WhiteBeard, January 15, 2013, 05:39:47 PM
WhiteBeard
I need to get a pair of new rotors for my front '88 FZR rim, and I'm looking at what Spiegler and Galfer has to offer (having already decided against the Chinese knockoffs).
Should I be getting a standard FZR rotor, or a wider size?
Cheers!
:drinks:
/Nat
I have the Chinese Galfer wave rotor knock-offs. Blue dot calipers and SST brake lines. Absolutely happy with the results. I am wondering why you have discounted using the Chinese rotors?
I don't know if this will help you but I used this site to check on OEM rotor spec's and look for interchanges. In the search box type in the bike the rotor's came off of.
I am not affiliated with the site so no conflict there. Just information.    http://www.metalgear.com.au
What kind of fork do you have?     :unknown:
The FZR rotors are bigger diameter than the FJ, but the same bolt pattern as 17" FJs (without looking, 320mm vs 285mm or something like that).
Quote from: not a lib on January 15, 2013, 08:12:33 PM
I agree. purchase 88 through 93 rotors and attach them to your FZR rim. everythink should mate up perfect.
Here is a possible option. EBC is a well known and respected brand
http://www.ebay.co.uk/itm/EBC-XC-Series-Contour-Front-Brake-Rotors-PAIR-1989-1992-Yamaha-FJ1200-MD2001XC-/181004087682?pt=Motorcycles_Parts_Accessories&hash=item2a24af3182
WhiteBeard
I'm using a set of '93 FJ1200 forks and a 3.5'' FZR front wheel.
Great site, George. Thank's for the link.
And thank you for the advice, Fred. I really like the look of the EBC rotors.
No real reason why I discounted the Chinese copies in the first place. I was considering it for a while, but now I feel like spending the extra cash for quality brakes and a peace of mind...   :crazy:
While we're at it, does anybody know if this:
http://www.spieglerusa.com/peak-evo-brake-rotor-2341.htm
is the same as this:
http://www.spiegler.de/product_info.php?info=p17690_Bremsscheibe-PEAK-Evo--298-mm-YA07.html
Different company logos, but same rotor???
Thanks,
Nat
markmartin
I installed the EBC rotors last spring on an '87 FZR wheel, have 5000 miles on them and have no complaints.
you need fj rotors not fzr.  with your wheel you need the 89 and later ones.
some guys have bought the Chinese rotors and have had no problems .
I bit the bullet and bought the ebc pro-lites and have been very happy with them. they are cheaper than the stock rotors.
ebc-hh pads as well.
WhiteBeard
Just bought a set of EBC Pro-Lites for the late model FJ's.
:good2:
My Galfer knock-off rotors from China. $194 for the set. I have about 5,000 miles on them and they are holding up really well.
craigo
Quote from: WhiteBeard on January 17, 2013, 06:57:33 AM
:good2:
I highly recommend you use the HH Sintered pads with those rotors. I used a set of semi metallics at first and got a lot of chatter out of the brakes. Switched to the HH pads and now it's just a happy memory.
CraigO
CraigO
90FJ1200
