Motorcycle Drag Race in Hungary - Aug, 2013! Who's Going With Me?
Started by Lotsokids, November 08, 2012, 02:22:56 PM
if your fj has anti -dive forks you are more like a 87 ,so it would be 41 teeth.
Mark is correct.... stock with the anti dive 1200s was 17/41
17/40 should be right on a 3CV.  Also was the best gearing that I used at the track with mine, though that was with the YZF wheel; equal to 17/41 on stock tires.
Lotsokids
Thanks. I was looking at Randy's RPM parts website and it seems my only options are 39, 40, and 42 teeth. I wonder if I should just go with a 42, but keeping in mind the nearly 6-hour ride to the track.
http://www.rpmracingca.com/proddetail.asp?prod=RearSprocket
The 40 was decidedly faster for me than a 42 (41 vs 43 if you correct for the tire).  If you're not replacing the chain, go with the 40, which will give you more wheelbase and make it easier to launch hard.
Scroll down to Performance Spec's. I don't know how accurate the info is but it seems reasonable.
http://wiki.gfm.net:443/FJ1200_Specs
Lotsokids
I hope you ordered the steel one and not aluminum.  the fj turns those to cheese.
Lotsokids
Quote from: Mark Olson on January 14, 2013, 09:43:26 AM
Yes, it's steel. Good to know, though!
I got enough miles out of a aluminum rear sprocket to go through a good set of Dunlops -- but that also included just over 100 drag strip runs. Used aluminum since it was the only thing readily available for the PM Chicane rims.
