FJ1500 Turbo EFI Katanaha Project, with a whiff of Nitrous...
Started by Havoc, October 25, 2012, 10:29:50 AM
dixiethedog
Now let me see,has anybody fitted a gsxr11 turbo engine into an FJ1200?........... :lol:
Havoc
Quote from: dixiethedog on March 04, 2013, 12:24:10 PM
The lump is tiny in comparision, might be able to get two in there  :diablo:
Dangerous Brothers Racing
Havoc
Wiring up the ECU.
First I had to make up the 35 pin block connector. Wiring diagram nice and clear.
Making up the block pins.
Slowly, slowly.
Buffalo solder, dreadlock wiring...
Wires pulled through a waterproof seal, the fat wire is the shielded wire carrying the inducted mA signal from the crank.
Getting there.
All done.
Now I need to make the loom for all the boring stuff like lights, horn, clocks etc...
craigo
CraigO
90FJ1200
I think I would have put the wires thru the seal as I was wiring the connector... Looks like it was a bit of a PITA.  Can't wait to see the video of it running.   :drinks:
Havoc
JPaganel
1993 FJ1200 ABS
1984 FJ600, up on blocks
I don't want a pickle
Havoc
Evening man. They are 2009 XJR1300 with secondary butterflies removed, air-to-exhaust port emissions rubbish removed, injectors replaced with 680cc DEKA items. I may replace them with something with a larger bore or go Meth/water injection to in the future if I have to run too higher boost to force mixture through and inducing detonation.
fintip
fjowners.wikidot.com
-ZAMM
IBA:54952
Havoc
I have to machine up an outrigger bearing/clutch slave housing, an engine cover to house the 36-1 trigger wheel and pickup (going to take some work to make it look less ugly, first one I made was very agricultural), finish the wiring, rebuild the clocks so they will read over 200mph (just in case) then set the old girl up on the DYNO. Unfortunately I'm getting very little time to work on it at the moment, it's exam time at work so I'm in 12 hours a day and to tired to get up the shed in the evening. Back on it in a few weeks, hopefully ready in 6-8 weeks...
If not, I get 6 weeks off over the summer so it'll come together quickly then, already at least 2 years passed the original deadline  :drinks:
Havoc
Didn't like the lines of the head cooler feed line. Cut through too many other lines and looked 'tight'
I struggled to get the feed to follow the frame lines so I made a longer one. Looks better I think.
Should finish the majority of the wiring this weekend.
If she suddenly goes missing, and all that's left is a plastic katana model, your bikes in my shed  :biggrin:,, not that I like kats or anything mate  :good2:
fintip
-ZAMM
IBA:54952
JMR
GhostMerc
New line looks better.  I think it's one of those things that nobody notices until you point it out though. Now that I've seen it, it can't be unseen.
Keep up the good work.
1986 FJ1200
2015 FJ-09
