getting her back on the road
Started by Goetz, October 03, 2012, 08:35:34 PM
Goetz
tym, klavdy, that is exactly the kind of advice i needed :good2:
btw, should i take the scoops off AFTER i remove the fairing??? they were a pain to put back on, with the fairing on the bike. wait.... i should RTFM eh...
Quote from: Goetz on October 05, 2012, 02:37:47 AM
so there is a company that sells sight glass kits :http://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&ved=0CCkQFjAA&url=http%3A%2F%2Fnewrivercyclesalvage.com%2Fsight-glass.html&ei=iYtuUPOHOorQ9ATtq4D4CQ&usg=AFQjCNGH5avXfmLFXn2ewLevJJ7I997hBQ
but a dime fits in the hole pretty well and jb weld is cheap.... i know, i know, but my inner redneck is howling with delight at the prospect of putting Jb on the bike... :yahoo:
DSC00249 by goetzjordan, on Flickr
DSC00248 by goetzjordan, on Flickr
An observation from the 2 photos. Is that the master cylinder that came with the bike?
You mentioned that you ordered a new sight glass. I am assuming you ordered one for a 84/85 FJ1100. The master cylinder that is in the photos is not a stock FJ master cylinder. I appologize if my assumption is wrong.
Goetz
No, that one came off of a moped, make unknown. Stops the bike just fine, but no brake light or mirror hook ups on it.
Goetz
 :blush:Yamaha FJ1100,1200 84-93 Clymer Service Manual ENG
i see, my air scoops were not held on by the oem push lock pins, but by two different sizes of bolt. made it tricky and explains some of the cracks. i may just drill access holes later....
Goetz
thats probably what i'll go with ifthesight glass replacement doesnt work. Thanks!
Goetz
so, another quick question. im running 4.5krpms in 5th gear @ 75 mph. does that sound right? and this thing will flat out GO. Cleaned the pods and it feels like the acceleration is a little better in the higher gears.
Quote from: Goetz on October 06, 2012, 05:54:58 PM
Ya, sounds about right to me!
Goetz
Thanks, she certainly doesnt seem underpowered. Lots of low speed, low gear clunk tho.
Goetz
Spin on oil filter adapter from RPM just came in the mail! Thanks, Randy! Clear instructions and documentation, 5 stars! :good2:
Has anyone here used evap-o-rust on exhaust headers before, mine are quite crunchy. im thinking de rust, sand, and grill paint.
wish aus post delivered here on weekends  :good2:
Goetz
Bearings for the f4i swap just came in, clutch lever came in, fork seals on the way, parkway trip on friday. Gonna need to skip the gym this week. :i_am_so_happy:
hi mate, what bearings did you get for the f4i,, I'm changing the top bushing out for the 3 bearings as used by another member , interested to see if it makes any difference
Goetz
eeeeh, i got two for the bottom and pressed the stock one into the top, that way i diddnt need a spacer. I used...HK1812 Needle Bearing 18x24x12 TLA1812Z Needle Bearings   $4.95
Sold by : VXB Bearings
they slid right in to the bottom mount and i used the f4i seals, which, fit pretty well. Its a bit too high now, how do I lower it, crank the bottom doohicky to the left or right?
Goetz
Fork seals done, 20 wt fork oil, and this thing has a front end again! Brake pads thoroughly cleaned. now it stops. spin on filter adapter installed, why the hell does the oil drain so slow. Is there another drain bolt that im missing? btw, the old fork oil looked like used engine oil and smelled like fish. :bad: Usb power cable routed and tied off, No w all i need is a long weekend :yahoo: :yahoo:
Parkway here i come!
Kokaloo
list of mods/maint so far, 8 days owning the bike
fork seals, 20wt oil
F4I rear shock
usb power for the stuff that needs it
oil change
choke cable replaced
hope i put everything back together right, BRP on friday. Deals Gap on monday, its a good weekend. :yahoo:
