Yoshi 4into1.
Started by Woodsman, September 14, 2012, 05:01:47 PM
Quote from: Woodsman on September 29, 2012, 03:25:31 PM
Do the 303 and 202 have the same dimensions in relation to the seal?
Cheers, Sean.
I do not know, I have never researched the 202, I was told years ago the 303 fit and that was when I added them to stock. The problem with the K&N website is they do not offer the specs of their filters like the WIX site does.
Randy _ RPM
Quote from: Woodsman on September 18, 2012, 01:24:22 PM
Ok, my spin on filter adapter from RPM is on it's way. Which filters can i use with the adapter? ( might be different over here?).
Will wait for it to arrive before i change the oil. If i drop the oil from the left oil cooler hose will i need anything else? Is there any gasket or seal that might need replacing or does the hose just bolt up again?
I did a little reasearch and Found out that the oil filter from a 1988 Acura Integra 1.8l engine is a direct match.
Quote from: aviationfred on September 29, 2012, 04:09:48 PM
As long as you find a filter with 20x1.5mm threads and it does not block the output holes of the adapter any filter will work. Most Import cars use filters with that thread pitch, it is just finding one that seals properly that seems to be the biggest tissue.
