Vibration
Started by winddancer, September 13, 2012, 10:29:25 AM
winddancer
Quote from: ribbert on September 17, 2012, 10:49:28 AM
Quote from: winddancer on September 16, 2012, 03:27:01 PM
Thanks for all the response I had carbs sync about 4-6 months ago and I regularly remove the front mount and lube it with hi-temp grease. I am taking it to randy next week I might need to pull the engine and check the rears.
Save yourself some work
I am defiantly going to install that
bigbore2
I have a question, why is that mount, the inner piece, made of aluminum when all the other front mounts are of rubber. [84-1100]
Quote from: bigbore2 on September 17, 2012, 04:20:51 PM
good question mate, going to ask that myself , and can it be changed for a rubber mount
Randy at RPM is working on a kit for the 84 to 87 years to upgrade to rubber mount.... I want one...
thanks for the heads up, after taking mine apart at the weekend , well all except the stuck alloy one rubber ones would be good all round
56 CHEVY
Quote from: FJmonkey on September 18, 2012, 07:31:33 PM
Me too.
Randy installed a prototype rubber bushing kit in my '84 when he did my (excellent) engine work.
You really really really want this kit. Really.
 :shok: your a lucky guy pat  :good2:
IIRC, the factory beefed up the frame when they went to the rubber engine mounts, because it was originally designed to have a solidly-mounted engine, which provides some stiffness to the frame.... I'm not completely sure the change will be a good one, long-term.
bigbore2
One could always weld on some extra steel to act as stiffeners if one knew where to put the extra metal.  Kawasaki used to do that to Kawa 500 Baja 1000 frames to strengthen them.
Quote from: bigbore2 on October 01, 2012, 06:48:26 PM
I've already done that to my FJ.
I call them 'Renntecs'.     :pardon:
