GPS mount for Garmin Nuvi 755
Started by FJmonkey, September 06, 2012, 07:58:03 PM
Worried about it falling off now and again?
Stick it on with some clear hot glue.
You can peel that stuff off later.
With the mount,you want the lever on the up(high) side.
Turn the whole mount 180 deg.
This gives a better viewing angle.
Fluffy should have pics of his rig.
His GPS rig that is.
MACHV
Sorry for the small pic. They cshould be much bigger but no matter what other way I past the URL, I get the little red X's.
I too had the single ball, fork stem mount left over from when I had my CBR600RR. It turns out the neck of this little beauty fits right into one of the bolt holes for a reservoir/stearing arm clamp. I had to bore out the Ram neck to accomodate the size of the bolt neck. But first I went to good ol' Ace Hardware, where they had the exact length in the exact bolt to accomodate the additional Ram mount length. Threw on a stainless washer for good measure. Tightenned down as normal. Routed the power cable and hit the road. All I need is a better GPS.
"I can assure you with no ego, that this is my finest sword. If on your journey, you should encounter God, God will be cut"
MACHV
I completed my GPS mount install. It looks like this:
And I installed a temporary voltage meeter to monitor till I figure out my stalling at speed problem. So the mount with GPS looks like this.
Blocked fuel gauge, works some of the time, I still watch the trip meter (old school). Blocked clock, who cares what fucking time it is. If it is light out then I use my tinted visor, if it dark then I switch to clear. If its wet then I put on rain gear. If I think I am late, go faster....
Ppppfffftttt gps, who needs it, i never get lost ppl keep telling me where to go :biggrin:  nice install monkey ranger,  fuel gauge, , they lie anyway, , mine shows empty at half a tank
Quote from: fj11.5 on September 27, 2012, 07:32:22 PM
But you always seem to end up at the same few places eh?
