front sprocket side to side movement
Started by bigbore2, September 04, 2012, 05:43:42 PM
bigbore2
84 1100--Putting on a new chain and sprockets and noticed that when i tightened the front sprocket nut down [61 lbs. torque] the splined washer lock tab and sprocket [18T] are loose a little.  The nut just tightens down on the shaft and not against the lock tab and sprocket??   Put a little grease on the tranny shaft splines??
Have you compared the thickness of the sprocket to the one you are replacing?.... sounds like its too narrow. I f you have to add spacers, make sure you add the same amount on both sides to maintain proper alignment.
yamaha fj rider
I agree with Harvy. Something is not right, time to investigate. Hope this helps.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
WR250F
Quote from: yamaha fj rider on September 05, 2012, 12:39:48 AM
Kurt
Tighten till it strips, back off half a turn and bend the tabs on the locking washer...  :shok:
remind me, never ever take up your offer of a ride on your Fj monkey  :lol:
Quote from: fj11.5 on September 05, 2012, 12:54:50 AM
Damn! I need someone to catch my chain and sprocket when it flys off. I will be way too busy keeping my Power Ranger suit clean to bother with lost drive train parts....
Make sure you put the recessed portion of the nut towed the sprocket, if not the nut seats on output shaft and will leave the sprocket & lock ring loose.
That should read, "toward" the sprocket.
nice save randy, , towed is what monkeys bike will be, don't think ill follow him either.  :lol:, ,
bigbore2
Randy- I think that is what is wrong as I am pretty sure it is on the other way.  I should have thought of that myself but saved by the brain trust.  Thanx
bigbore2
Yep was on the wrong way. Flipped nut over and all is good.  Randy, owe you a beer.
Quote from: bigbore2 on September 05, 2012, 07:04:21 PM
The last front sprocket I got was not handed, The same if installed either way. Good to know when I need a new one. Check for proper orientation and tightness, might be good advice in brothels and blind dates as well.  :biggrin:
Quote from: FJmonkey on September 05, 2012, 07:13:13 PM
Not the sprocket...
the NUT...
Slow down Monkeyman...
Quote from: racerrad8 on September 05, 2012, 07:28:26 PM
Not the sprocket...
the NUT...
Even more important if we are talking about my FJ's Nut.....
yamaha fj rider
Bad FJmonkey Bad. What happened to FJmonkey see no evil, hear no evil, speak no evil?  :lol: :lol: :lol:    (popcorn)
Kurt
93 FJ1200
FJ 09
Tenere 700
FJR1300ES
WR250F
