This n that
Started by nurse, August 31, 2012, 03:27:25 PM
nurse
Went out for a couple of hours this evening and felt well, withe exception of a couple of things. Firstly for about the first half hour the bike felt quite skittish almost wobbly wavy when cornering at anything under 40mph, any thoughts? Not noticed it before
Also since having fitted my new fjr clutch I have experienced nothing but beautiful gear changes, however for the last few outings I have struggled to find neutral exactly when I want it.  I can feel it slotting in, but then if going down it slots into 1st if going up it slots into 2nd.  Any ideas?
First 1/2 hour you say, check the air pressure in both tires. After 1/2 a hour the air would have warmed up and the pressure increased enough to stabilize the tires in the corners. Just my $0.02.
nurse
I think That's about  1 pence this side of the pond.  Thanks monkey, will check in the morning!
Any thoughts on the neutral thing!
I've just bought an Fj12 back from the dead , well sat untouched for 4 years, had the same type of issues with the clutch, start off with wouldn't change gear at all unless moving , turned out to be stuck clutch plates from sitting so long, freed them up by putting bike in gear and rocking back and fowards, also changed master as since he owned it clutch only moved 5 mm from the bar and off you go scary ,, bleed her again  and see how you go
FJSpringy
maybe try a Factory Pro, Pro Shift Kits (http://www.factorypro.com/products/shift_kit,Factory_Pro.html) or maybe randy has something similar.
I have kleptomania,
but when it gets bad,
I take something for it.
92 FJ1200
Air in your clutch circuit. Bleed it again and see if that helps.  Cheers
Quote from: FJSpringy on August 31, 2012, 05:14:00 PM
Randy has a shift kit, got some good reviews and it's on my upgrade list.
It's the same kit. Randy installed one in my bike. It's a great addition. Snick snick smooth shifting.
yamaha fj rider
Do you guys use the clutch on up shifting. I guess too many years on a dirt bike. I normally use the clutch stop/start and some down shifting(normal riding) when under hard acceleration I will slip the clutch but that is it. Your thoughts please.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
tmkaos
Quote from: yamaha fj rider on August 31, 2012, 10:04:55 PM
Kurt
I clutch it up through into 2nd, then after that it's just a roll off and clutchless up shift. I clutch on the way down, and I find it changes MUCH smoother if I blip it as I shift. Not a big one, anything over about 500rpm up from wherever it is currently works a treat. Otherwise I feel a bit of a "clunk"... Particularly into 1st.  Standard clutch componentry all round on a '92 with 140,000kms
James
'92 FJ1200 - '07 to present
'83 VF750S Sabre - '04 - '07
'87 VT250FG - '94 - '98
