Rear brake master cylinder
Started by lyonsee, July 27, 2012, 04:21:17 PM
lyonsee
Put the ace back end on the FJ, but the banjo fits to the side of the master so on full compression it fouls the swing arm is there an easy way around this.
Quote from: lyonsee on July 27, 2012, 04:21:17 PM
Pictures are worth a 1,000 words on this one....
lyonsee
Quote from: FJmonkey on July 27, 2012, 09:39:52 PM
Found a brembo master cylinder with the banjo fitting on the end,one small bracket and some grinding later sorted..... :good:
Here's what I did: I got rid of the big fat hex head banjo fitting and used one of these low profile allen banjos with copper washers
(Google: Pro Bolt):
Note: This is the mfgr's sales photo, I do not have rubber brake lines!!!
Also, get the back end up, even when under full compression, the swing arm will be below the fitting.
