clutch and oil filter
Started by moonrunnah, July 14, 2012, 08:10:08 AM
yamaha fj rider
Some brake cleaners and the citrus based degreaser will remove silicone. Hope this helps.  :unknown:
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
moonrunnah
Quote from: bigbore2 on July 25, 2012, 08:30:58 PM
What kind of RTV are using and how do u get it off?  I would never put RTV on aluminum, but I just have a gasket scraper to clean it off with.  One always removes some metal no matter how careful. What is the secret here?  I have a valve cover to do on my car and wnat to put on RTV to insure a seal, but removal?
i have an anlge die grinder with a rubber bristle thing on it i had to buy it when a was working at a garge but if your going to use it once of twice spending over $100 is just nuts
the diesel rtv i was getting from the ford dealer works really good its for the oil pan on the older 7.3l diesel engines.
http://www.mechanicstoolswarehouse.com/Standard-Duty-Multi-Purpose-Air-Angle-Die-Grinder-P18453.aspx
this one is under 60 and IR makes really good tools
http://www.bing.com/shopping/3m-scotch-brite-roloc-bristle-discs-3-120g-white-roloc-bristle-disc/p/F3BBE31FE20C0E825006?q=3M+Roloc+Discs&lpq=3M%20Roloc%20Discs&FORM=HURE
these are the things you use for aluminum and you will need a rol loc arbor or 3m makes it you can get at walmart for an other $14
When in doubt throttle out
bigbore2
Thanx Moonrunnah, I have a die gringer and compressor, so i just need the bristle thing.
moonrunnah
no problem im glade i can help for once
i have a bunch of different attachments witch is handy but dont use the steel of cast iron one one aluminum that will ruin it big time  :wacko3:
good luck   :drinks:
