Is this worth repair or parts?
Started by 1990FJ1200TX, June 10, 2012, 02:23:29 PM
1990FJ1200TX
I have a 1990 FJ 1200 that was in excellent condition, but has sat for over three years in my parents garage unused.
History:
The bike first sat for a few months, and when taking it out it was running a bit rough.   At that point I ran it dry (I assumed old gas was the culprit), put it on the center stand, and took the battery out, but no other prep was done for storage.
Today I cleaned the carbs, tossed in two gallons of gas, put her in neutral, and hooked up a battery just to see if she'd live before changing oil/filter/bleeding brakes/etc.    While she turns over, unfortunately there is just a strong smell of gas coming from the exhaust.   Let it sit for ten mins and tried again with the same result.
Unfortunately, I don't have the time to invest in fixing it nor trailering it back to my house, and was wondering if anyone has experience reviving a machine that has sat so long or if its better to just part her out.
Anyone know about how much it would go for if running vs just a parts/fixer upper?   KBB only lists $1880 for "excellent" condition, so I am guessing selling it as a parts/fixer upper is the answer, but would still be helpful to have a really rough ballpark number to go with.
PS: I'm riding a Suzuki DL650 these days; totally different kind of bike but she works for me.  :)
akwusmc
It's definitely worth repair, as long as there isn't anything major wrong with it. My bike's been sitting for about 3 years and I['d never think it would start and run without some fairly intensive maintainance.
Give a little better description of the overall condition, as well as color or the bike and where you are, and someone will get you a better answer.
SlowOldGuy
Does the TX in your ID stand for Texas?  If so, where?  (or if not, where?)
Quote from: SlowOldGuy on June 11, 2012, 02:11:37 PM
Yeah, it's a small enough state, you guys are most likely neighbors :)
SlowOldGuy
I'll bet he's within a 3-day drive.  That's practically next door.  :-)
RichBaker
Carbs are still dirty.....  Good luck.  No reason for anything else to be wrong, all she did was sit and build varnish.....
Tennessee Squire
90 FJ1200, 03 WR450F ;8^P
yamaha fj rider
Three years is not that long for a bike sit. Sounds like carbs, fix that you should be good to go. If you can't fix it then send them to Randy (first choice) or a local shop.
Kurt
93 FJ1200
FJ 09
YZ250X I still love 2 strokes
Tenere 700
FJR1300ES
WR250F
