power boost vacuum advance unit
Started by saltyfj1200rider, May 24, 2012, 06:36:33 PM
saltyfj1200rider
I am a new owner of a 1990 fj, I am vary impressed with it overall. I have a problem with the idle hanging. I can use the clutch to pull down the rpm's at a stop and it will idle ok but  the motor dose'nt drop between shifts as it should. I cleaned the carb's and it was somewhat better,but still hanging. I disconnected the  power boost vacuum advance unit and pluged the line ,the hanging idle was gone but a slight reduction of performance was noted. Should I replace the advance unit or is there a better fix?
moonrunnah
just my 2 cents but is throttle sticking open a little i had that problem and i was just a little adjustment and it was fixed
When in doubt throttle out
saltyfj1200rider
I checked it, cables are good with no binding
saltyfj1200rider
Using the motor to pull down the rpm's would eliminate that possibility.A stuck throttle is A stuck throttle. Thank's
Air leak on your intake side, spray WD-40 (Or is that carb cleaner?) around the carbs and intake boots during idle. If the idle changes, you have a leak.
saltyfj1200rider
I also tried that, no leaks found. I just bought a good used sensor on Ebay $30, I will post how it worked out Thank You.
moonrunnah
56 CHEVY
Could one or two plugged pilots be a possible cause? My guess would be a lean condition also.
mreed112
Make sure that you have no cracks in the hose going to the unit especially where the hose plugs to the #2 intake.  I have had that problem a couple of times.
I was not aware that the 1990 FJ's used a vacuum advance. I thought they were a DCI ignition.
My' 92 has a vacuum hose coming off the #2 carb manifold which runs up to the front under the fairing for the reserve petcock functions.
weymouth399
:shok: :scratch_one-s_head:
You may want to check that out, it would be the only one.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
So Bob, the 90's have vacuum advance? What would the vacuum hose on my '92 do?
Travis398
The digital box alters the timing, but it uses sensors to determine the adjustments needed, (e.g. pick up coil and pressure switch.)
Think you guys may be barking up the wrong tree.  I'm guessing a synch would fix it.
Travis398
