Brake line end orientation for blue dots?
Started by markmartin, May 13, 2012, 07:17:17 PM
markmartin
I've  received the blue dot calipers and see that I'm going to need new brake lines, as the orientation of the attachment point at the caliper is different than the FJ's brakes.  It looks like a straight end with no 15* or 22* off set is needed at the caliper but I'd sure like some confirmation of this before ordering lines.  can anyone check to see on their blue dots if the line end comes straight off the caliper and on it's  way to the master?
Or a close up picture would be great.
Mark
Quote from: markmartin on May 13, 2012, 07:17:17 PM
Mark
Why didn't you ask earlier?? I have the bike all covered up for the night now. Having recently installed Blue dots, the connection at the caliper is not straight. You want them pointing away a little to clear the forks and not foul up or chafe on anything. Maybe I will pull the front of the cover up and take a pic or two for you. Consider it my Red Power Ranger good deed for the day.  :blum1:
Steve_in_Florida
Quote from: FJmonkey on May 13, 2012, 07:22:58 PM
...Red Power Ranger good deed for the day.
Mark, you're a  hell of a guy!
`90 FJ-1200
`92 FJ-1200
IBA # 54823
JMR
I used Speigler 90 degree fittings at the bottom. Mint
markmartin
Great, thanks for the pictures Mark.  That  answers my question on the bend.   I'll mock up with clear tubing tonigth to get a length for the lines.
JMR, thanks, I'm assunming you mean rotated 90* as compared to the FJ.  So, yes, thanks for the confirmation on that too.
JMR
Quote from: markmartin on May 14, 2012, 08:52:31 AM
http://spieglerusa.com/standard-line   If you scroll down to the fittings it is fitting 090. Used a standard straight banjo at the master
markmartin
Quote from: JMR on May 14, 2012, 09:56:46 AM
Hummm.... interesting .  I'll take a closer look tonight.  So it would be bent up at 90* and to the side 15* or 20* as in FJMonkey's photos?  FJMonkey's photos look like it's straight with a sideways off set by 15* or 20*.  It looks like the fitting is up against the stop as it should be in the last photo.
Do you have a photo??
JMR
Quote from: markmartin on May 14, 2012, 12:32:26 PM
I will have to set up an account to download pics on to....I guess I can have my oldest son do it Monday when he returns from college. The 90 degree bend is on top.....I did have to grind down 1 banjo stop on the calipers. It leads the lines straight back with a nice arc towards the master. I'll try and get some pics up.
JMR
Quote from: JMR on May 16, 2012, 08:45:25 AM
Looks like I will be able to get some pics up Monday
markmartin
JMR, I followed your link to Spiegler and that was a huge help.  The offsets were one issue, but then the twist and how much and to what side to twist was another issue.  I've had to reorder SS lines before because I had ordered the wrong twist .  I spoke with a representative at Spiegler and they told me that their fittings are able to be twisted with a special tool that they send with the custom lines.  I've ordered the lines with the bends that seemed to make sense and will twist them accordingly when I fit them on.
Once again, much time and frustration is saved with advice and experience from the members of this forum, so a big thank you to y'all!  I'll post some pics when I get the whole works together. Hope it all fits!!  :i_am_so_happy:
JMR
Quote from: markmartin on May 16, 2012, 01:53:38 PM
Right...it makes it much easier
