Opinions - what chain lube do you use and why
Started by terryk, April 01, 2012, 09:49:42 PM
castrol ,sprays on foamy ,best use on a warm chain with the straw instead of exploding out of the can nozzle onto the tyre = lots of extra clean up , ,,last a month or so, or till the. links look dry, very little fling off if used properly , dousnt seem too attract dirt ,  :good2:
Quote from: simi_ed on April 03, 2012, 03:02:28 AM
Randy, how do you apply the gear lube?
I just snipped a small opening off the tapered nozzle on the bottle and spin the rear wheel by hand for two runs of the chain.  One round I drizzle it on the outside of the chain at the rear sprocket, then another round on the inside on the bottom run.  If the chain is warm, it spreads right out.
eddohawk
http://www.ebay.com.au/itm/Universal-V-System-Scottoiler-Chain-Lube-System-/190320204572?pt=UK_Motorcycle_Parts&hash=item2c4ff7db1c
For those interested in buying a Scottolier hers where I sourced mine from. At a dealer in Melbourne they were asking $220 I got this one for AUD $135 incl postage. Havent worked out the likely pay back yet after taking into account oil refills, what I previously spent on chain lube and the likely longer life from chain and sprockets but just not having to lube my chain every week and clean the crud off is good enough for me.
DB Cooper
I made a semi-automatic chain oiler using clippard valve components. The resovoir is an old bicycle chain wax container, and I fill it with 80W90 hypoid gear oil. I have it set for one drip every 3 minutes, works a treat! Cost was about 60.00 Canadian. I flip the toogle to on before the ride, and hope I remember to flip it off after the ride. A 6 inch length of 20 guage wire inserted at the end of the hose just above the chain allows it to bend in just the right spot just above the chain and before the rear sprocket.
Kevin
I remember when sex was safe and skydiving was dangerous.
Kevin,
Nice job.  I really like those Clippard parts.  Can you tell me where I could get the toggle valve?
I've got a similar system on my FJ. which uses a reservior just under the fuel pump and siphons (bar & chain) oil over to the left and along the swingarm before depositing on the chain.
Are you able to access the toggle valve with the seat and sidecover in place?
DB Cooper
Hey Arnie.
Thanks!
Yes, it's easily accessable at any time, even while on the move if need be (especially nice for when I have a brain fart and forget to turn it on).  The website is clippard.com in the US, the toggle valve is clippard part # TV-2S, and the flow control valve is MNV-4K. A buddy of mine machined up the nipples, but you can get them from clippard as well. The hose came from clippard too (oil resistant stuff) but for the life of me, I can't remember the type or part number. I'll dig through my parts bin tomorrow, and get the part number for you if you need it.
Kevin
Nice oiler, Kevin.  Simple, not too much money.  I like it!
eddohawk
Pretty impressive set up you have there Kevin. I havent priced the ''scottolier refills'' as yet but I'm guessing they'll be expensive. I'll try gear oil when its time to top up.
baldy3853
Quote from: DB Cooper on April 03, 2012, 06:14:52 PM
Kevin
Very nice Kevin this was also going to be my responce as well but my switch was a common old garden tap diverter but they had to be replace every 6mths or so when they started to screw up, but a much better way the using chain lube
baldy
Randy, get on with it, you have another project to add to your list. An RPM chain oiler....
On the Clippard website they have solenoid operated valves that will turn the flow on/off automatically if you hook them to a switched lead.  Cost was about $50 plus shipping.  That's what I'll get soon instead of a manual valve I keep forgetting to turn off.
Part # ES-2S-12
http://www.clippard.com/store/byo_electronic/byo_es_valves.asp
DB Cooper
Hey Arnie.
I did see the electric valve, but opted for the manual valve instead. I'm not really sure why. A buddy of mine ordered some stuff from Clippard at the same time as I did, and he got the electric valve instead.  It seems to work really well, and it's turn the key on / off and forget about it. He did install a simple back up switch on his so he could turn it off if for some reason the solenoid ever became stuck or whatever, but he's happy with the setup.
Thanks for all the kudos!
Kevin.
Quote from: Arnie on April 08, 2012, 09:20:58 PM
Part # ES-2S-12
How do the lines hook up to that type of valve?
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
Looking at the pic available on Clippard's site, you have a choice of 4/40 threaded connectors, or 1/16" barbs, or 1/8" barbs.
