Re: Additional fuel capacity
Started by Pat Conlon, March 10, 2012, 11:00:26 AM
Quote from: Mike Ramos on March 10, 2012, 01:15:33 AM
"....Bear in mind that I carry 11 gallons of fuel, thus there is approximately a 70 pound difference between full tanks and reserve by the time I stop for fuel......."
11 gallons of fuel?
Mike Ramos
Top of the morning Pat,
Yes, that is correct...
Mike Ramos.
Quote from: Mike Ramos on March 10, 2012, 11:08:01 AM
Mike Ramos.
Tank bag with a fuel bladder maybe?
Quote from: Pat Conlon on March 10, 2012, 11:00:26 AM
11 gallons of fuel?
Do tell Mike, I'm sure alot of us would like to know how it's done!
E Double
Do you use something like this?
This one is kinda cool;
There are only two kinds of people who are really fascinating: people who know absolutely everything, and people who know absolutely nothing.
    Oscar Wilde
Mike Ramos
Good evening gentlemen,
No, nothing so exotic; I have a set of Coretech soft saddlebags with a matching tail bag.
I made a wooden mock-up of a tank that fit within the tail pack and then had a metal tank made to match. I chose aluminum, not as much for the savings in weight as no sparks in case of a fall. I also specified a lot of internal baffling to eliminate sloshing.
The tank is in the tail pack which is buckled to the saddlebags, along with flat bungee cords to make it extra secure.
I have an electric two way fuel valve located near the fuel pump (a fuel pump from RPM no less). The switch for the valve is located next to the stock reserve switch.
In addition I have a redundant in-line electric fuel valve to insure positive fuel shutoff.
The fuel line itself has a dry disconnect so it is easy & quick to mount and dismount.
Ride safely,
Mike Ramos.
Grey runner
So assuming that you get about 40 mpg does that mean you only stop every 400 miles? Thats very impressive  :flag_of_truce:
The older I get, the faster I was
Impressive Mike. I've heard folks doing these aux. fuel tanks for the Iron Butt events, do you participate?
Let's see, I have a Corbin seat, yep that's good for 400 miles, Vibranators and foam grips, yep good there, Penske rear shock dialed to soft, yep, that's good, heated gear, good there, a large Camelback full of ice and water, check, ........
... now the only thing I would need is one of those condom thingies with a hose that I run down my pant leg so I can pee.....
No way my 59 year old bladder can last 400 miles....
The furthest I've ever made on my FJ is 860 miles in 17 hours. Wowzer, was I sore the next day.
FJ Flyer
11 gals is the limit for Iron Butt sanctioned rallies.  Coincidence or rally bound?
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
Quote from: Pat Conlon on March 11, 2012, 12:09:48 PM
a Pilot's buddy.
Fixed it for you Pat. My brother in the Air Force mentioned them. The military pilots stay aloft way longer then I can hold back either end.
Quote from: FJmonkey on March 11, 2012, 09:20:42 PM
a Pilot's buddy.
When I was in the USAF, they were referred to as , "relief tubes".
moonrunnah
my buddy got out a year ago he said they call them piddle pads
i guess it all refers the same thing pissing while riding  :good2:
When in doubt throttle out
Mike Ramos
Fellows,
No, no type of competition, Iron Butt or otherwise.
And I stop when needed, I have never been so much in a hurry to get from Point A to B.
The auxiliary fuel tank size was determined by the tail pack size.
As I said, quite basic.
Mike Ramos.
Mike Ramos
P.S. I got sidetracked...
The only reason for mentioning the fuel was that the front fork valves compensated quite well for the weight change between full & empty tanks.
I am short on time at this moment but I will expand on my experience with that modification at a future date, in a few days.
Regards,
Mike Ramos.
TheRadBaron
Speaking of military aircraft "pee packs", when I was an enlisted guy in the Marines a few years ago we found that you could tell a lot about a pilot by what he did with his used pack after his sortie.  The decent pilots would take theirs with them and dispose of it, while the arrogant jerk "I'm and officer and a gentleman" pilots would just leave it in the cockpit for us lowly, enlisted knuckledraggers to deal with.  Luckily I was a weapons tech and it was the ejection seat mechs that got that task.
My buddy was a seat mech, plus his NCOIC was in charge of the random urinalysis program.  He got to deal with used pee packs all the time and be the "witness" for the urinalysis whenever it was going on.  It was called "meat gazing".
Sorry, I know it's off topic.  Funny story, though.
The desire for safety stands against every great and noble enterprise.  -Tacitus
