One thing leads to another
Started by ELIMINATOR, February 28, 2012, 11:45:53 AM
ELIMINATOR
Added a relay, so that I can use my Stebel Magnum horn. While I had the tank off, as is the way,(jobs always end up with another job) I noticed some surface rust on the underside, out came the ACF50. :good2: Also took the opportunity to fit the iridium plugs, I've had for a while. Also let me see the colour of the old plugs, as I recently removed the end plates from the standard silencers. Well, one was loose, so I drilled it out, borrowed a rivet gun, then decided it sounded better, so drilled the other end plate off.
BMW 1150GS
Moto Guzzi California 3
