86 fj12 slip on exhaust
Started by moonrunnah, February 26, 2012, 06:07:49 PM
moonrunnah
Im sure this has been posted before but i did not find any info i wanted
Are there any slip on exhaust for an 86 fj1200 that does not need the carbs rejetted
im just looking for sound not power but i do not want to risk running lean and destroying my engine
When in doubt throttle out
Bearcat91
I saw those on ebay... how was the fitment? sound? quality?
Thanks!
Quote from: Bearcat91 on February 26, 2012, 06:44:25 PM
Thanks!
Sound and quality are 1st rate, but fitment for me required the removal of the center stand, BUT, mine were sold as designed for the Euro spec XJR1300, NOT the US FJ1200, so I can't say if they will fit any better, or not.
The sound is not too loud, and they look great, and that is what I was after.
101_1281.MOV
1991 Yamaha FJ1200 walk around
Quote from: 1tinindian on February 26, 2012, 06:34:58 PM
Delkevic
Have you removed the baffle (pretty easy one screw underneath in the back) and listened to them uncorked?  I'm sure you'd have to rejet but just wondering how much difference in loudness there is.
cheers!
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
Yes, I had pulled the baffles out and rode it.
Not much of a difference to my ears, and no jetting changes were needed, as the  engine ran very much the same, either with, or without the baffles.
So I left them in instead of loosing them in the shuffle somewhere.
Thanks!
I have the Delkevics as well.  The note is perfect.  I ran them without  baffles for a while but it was a bit hard on my ears around town without earplugs.  I refitted the baffles (only takes a minute) after the novelty gave way to pain and love the sound.  I too had to remove my centre stand but only because it wouldn't retract far enough for riding but can be refitted in seconds (without spring) for servicing or cleaning purposes. I found the best fit came from switching the L & R intermediate pipes over.  I don't think the casing is very thick and should be handled accordingly while fitting.  Also, make sure they are not tucked in too close so there is clearance for the axle to pass if they're mounted within the swing arc of the back wheel.
Exactly right.
I too, switched sides on the intermediate pipes, just fit better.
And before I put the 17 rear wheel on and raised the rear, my cans made light rub marks on them from the rear axle ends.
Funny, yours were alot louder, eh?
I could hardly notice a difference, wonder why??
[/quote]
There was no noticable difference at idle in the garage or when revving up stationary but I did notice a big difference under load.
moonrunnah
Quote from: 1tinindian on February 26, 2012, 07:12:05 PM
Thanks!
101_1281.MOV
what kind of back tire is on your bike i like and ive seen it before
im going to check in to those pipes i like those
Quote from: moonrunnah on February 28, 2012, 05:40:11 AM
It's a 5.5" FZR1000 wheel with a 180/55/17 Dunlop Sportmax.
