anti-dive block off plates
Started by Kennyg, February 09, 2012, 05:59:03 PM
ccsct203
Quote from: FJmonkey on February 10, 2012, 09:45:37 PM
Quote from: ccsct203 on February 10, 2012, 09:25:59 PM
I have 2 new anti-diver units in the boxes.... :i_am_so_happy:
I think I heard that you have two new flintlock rifles, or was that you have two new stone axes?  New AD units? Where on this planet did you find NEW ones? Or are they just new to you? Just want to know. You must be holding very true to OEM original.... Them AD units were more hype than useful. Notice how the years after don't have them? If you are sticking to OEM original then Kudos to you. If you have new ones then why block them off? Or are we talking about the forks and not the AD units?  :empathy3:
I wish they were flint locks... then they would be useful
But I do have 2 new ones in the boxes off of ebay
I switched to a FZR front end but seeing that these were as hard to get and as useful as buggy whips I bought them
Pictures coming soon.... yawn
Quote from: ccsct203 on February 11, 2012, 08:36:41 PM
I am good with that, as you were...
Skivvy
Sooo, for us non-Luddites is there a source for AD block off plates?
if you remove the tapered spindle (flower pot looking thing) from the bottom of the damper rod then you can just use plain flat plates bolted onto the fork legs with some sealant.
you have to take the forks apart to remove the tapered spindle.
if you dont remove the tapered spindle then you have to use a block off plate that has channels machined in it for the oil to flow out and back into the fork legs.
there used to be someone who made these special plates but its been a long time and i cant find his information.
Quote from: Skivvy on February 13, 2012, 10:21:04 AM
SanDimas Mike got a set about 6 months or so ago. Where did you get them Mike?
Hemi Bob
Hi I saw this add on eBay for anti-dive block off plates
http://www.ebay.ca/itm/FJ1100-fork-anti-dive-block-off-plates-FJ-1100-1200-/280761718032?pt=Motorcycles_Parts_Accessories&hash=item415eb3d510
sorry if this link wont work. Go to eBay and type in the product code 280761718032
good luck
Robert
Robert
1985 FJ1100  Original Owner
1986 FJ1200  X Drag Bike
1981 Suzuki GS 1100ex
1981 Suzuki GS 750ex
Quote from: Hemi Bob on February 15, 2012, 09:50:37 PM
good luck
Robert
The price sucks and I don't see how the two ports allow fluid to pass. Thus causing hydraulic lock of the forks. The upper and lower ports need to permit fluid to pass freely with the plates in place. If they allow the fluid to pass then I will just settle on the price sucking.
moparman70
My guess is the ports don't allow fluid to pass but possibly they go over some protruding metal.  I haven't taken mine off to know but SanDimas Mike would know ....lets get Mikey ...ya lets get Mikey .... he knows everything
there is no protruding metal at the anti dive mounting location.... just two o -rings
Looking close at those ebay block off plates, looks like they are gun drilled from the bottom and then blocked off - so should pass fork oil and work with no issues.
56 CHEVY
I cuncur with fj1289. There is a hole drilled from the bottom and plugged so the oil will pass through just as the listing says.
One question. If I have installed Race Tech gold valves in the forks in my 86, would the oil still have to pass through? If not, I would think one could just make solid plates to block off the holes.
Quote from: 56 CHEVY on February 17, 2012, 11:00:35 AM
were the holes in the damper rod drilled out and additional holes drilled above the bottoming cone/ tapered spindle?   if so then you may be able to get by with flat plates.
Mike 86 in San Dimas
Quote from: moparman70 on February 16, 2012, 01:52:17 AM
Ah grasshopper my block offs do not allow fluid to pass. I installed my block offs when I had emulators installed. This mod does require that circuit. Could not find the person that made the plates. He use to participate in this site which is how I found him. He did not charge as much as the eBay option, but the eBay version looks a little better. When time comes to service the shock I will see about getting mine  beautified. I know I know I should get do a whole front end mod.
56 CHEVY
[/quote]
Yes, the holes in the damper rod were enlarged and the holes added per the instructions from Race Tech. I am a machinist, so I will make my own block off plates. If I don't need an oil passage, flat plates are simpler to make.
[/quote]
read my post left out key word. Should say mod (emulators) does NOT require this fluid circuit.
