ceramic coating the exhaust... who's the best?
Started by ccsct203, January 13, 2012, 09:01:05 PM
ccsct203
My V&H chrome exhaust is in need of a sandblasting and ceramic coating.
Who has had it done and where?
What finish did you have done and.... how much does a great job cost?
Thanks in advANCEEEEEEE..
Darn that cat of mine
Jet Hot is thinner, Swain Coating is thicker, both are good.
I have Swain's White Lightning coating on my '84's oem collector box, it is durable and it works: http://www.swaintech.com/store.asp?pid=10969
(I also have Swains TBC coating on my 82mm piston crowns and the PC-9 on the skirts)
ccsct203
I'm looking at it now.
$40 per foot?
I'll have to price both out and see which is the best value
thanks
Pat, does Swain do used pipes?  I looked at their site, but couldn't find it...  I did see where they normally don't do the inside full length.
JMR
 I have used Swain tech many times for piston coatings but never pipes. They are very nice folks to deal with. I have had HPC and Jet Hot coat pipes for me. HPC does not exist anymore. The Jet Hot coated pipes are OK. I'd recommend doing inside and outside.
Quote from: RichBaker on January 15, 2012, 02:08:52 AM
Rich, they will do only the outside of a used pipe. They say that they can't get the inside scrubbed clean enough for a proper bond.
I wanted them to do the inside of my collector box but they said no.
New pipes yes, they will coat the inside but only to a certain length.
You might be better off with the thinner Jet Hot coating if you want the inside coated.
