Additional lights on FJ1200
Started by johnf154, November 29, 2011, 08:27:24 AM
Does that trike have reverse too ?
looks like a very clean conversion!  :good2:
KOokaloo! (with three wheels)
Wow, excellent FJ mod,(Best colour too!) Hey mate, where did ya get the leading links from.  Doug
johnf154
Thanks for that Marsh. Please excuse my ignorance but what does the CA stand for in your location?
John
johnf154
Quote from: racerman_27410 on November 30, 2011, 11:31:11 PM
Thanks Racerman tried to keep it as simple as possible and not add too much weight, so cruises nicely up to 110 on test (whoops mean 70 if your looking from UK). Reverse is leg powered i`m afraid but reasonably easy, and look before hand to try position where no reverse needed. :yahoo:
John
johnf154
Quote from: The General on December 01, 2011, 12:17:01 AM
Hi Doug, found forks on ebay in uk. Apparently came off Goldwing sidecar, and have recently changed shocks for some new ones I already had as ones that came with forks had seized  adjusters.  friend who`s a whizz at engineering knocked up new top brackets as mounting were different. :wacko3:
John
moparman70
Quote from: johnf154 on December 01, 2011, 04:51:07 AM
John
California
johnf154
Quote from: flips on November 30, 2011, 01:01:15 PM
Hi there.
My first suggestion is get a good battery,the higher the CCA number the better.I have been running a H.I.D headlight (uses less power, 35w,and has much better light output)without any trouble for about a year now,although some members have posted quality/reliability issues.I also run a pair of little 55w spots via a relay off the high beam circuit,mounted on small brackets of the oil cooler.Have you done the headlight relay mod yet?
http://www.fjowners.com/index.php?action=gallery;sa=view;id=2377
or Harvey did it this way....
http://www.fjowners.com/index.php?action=gallery;sa=view;id=67Hi Jeff, thanks for the info. Currently have put no relays in at all. Your suggestion of bigger battery reminded me that (And i`m now going to show my age) in the 60`s (yeah that old) I had a Triumph Thunderbird to wich I added a double adult sidecar for a growing family, and fitted a small car battery in the boot and that worked fine, without other alterations for quite a few years.
Ride safe :diablo:
john
Jeff P
moonrunnah
nice mod
i had thought about doing something like that only with an atv axle and tires to off road  :good2:
what exhaust is on your trike i love it?
When in doubt throttle out
