Chain Question
Started by Medi, November 10, 2011, 06:33:01 PM
Medi
I need help with buying a chain.
I have a stock 86 FJ.
From what I've read on the forums I need a 530 chain which has 110 links.
I've found two recommended chains but they only come with 120 links...
http://www.cli-maxridinggear.com/servlet/the-2269/D.I.D-530ZVM-dsh-X-Super-Street/Detail
http://www.indysuperbike.com/customer/product.php?productid=700059
Can somebody point me in the right direction?
Thanks
Steve_in_Florida
Most shops cut the chains to length with a chain breaker and then rivet them together.
`90 FJ-1200
`92 FJ-1200
IBA # 54823
I bought a 120 link, had about 8 links taken off ,to fit my 16 /40 sprockets, very good Fit very little adjustment needed
Medi
Oh ok.. another stupid question, EK ZZZ chain specs say it's rated maximum for 1100 CC Engine. Am I looking at the wrong item?
Medi
I think I might as well do the sprocket upgrade.
Will this chain work with Randy's sprocket?
http://www.rpmracingca.com/proddetail.asp?prod=M%2FC%3A17t
Thanks!
Yep, that's a stock 530 sprocket.
Quote from: Medi on November 10, 2011, 08:17:01 PM
I suppose it depends on the chart you're looking at.
They're commonly used by guys with >500hp turbo busas at the dragstrip.  The ZZZ is damned strong.  Saw one guy using one on an aluminum (rear) sprocket on a bike with around 480hp.  Tore the teeth off the sprocket, but the chain was okay, and he reused it without problems.  Now, you're not going to get 30kmi from one in that situation, but with that kind of power, you're not going to get much life out of anything.
the ZZZ chain has been the only chain that survived on my FJ.
IMO it's worth every penny!
Medi
Thanks guys for the clarifications!
I ordered the sprocket and will order the chain tonight.
