Collars for belly pan mounting bolts
Started by coreyoreo, November 02, 2011, 11:32:54 PM
coreyoreo
Hello all,
Looking for a replacement solution for the 4 collars needed to mount the belly pan, (Yamaha part #90387-064W1-00 (Collar) but no one seems to have any...They're discontinued.
Not sure exactly what they look like or what they're made of, but anyone have ideas on what I could use instead?
Is it just a spacer that I could get at a hardware store?
Thanks for any help!!
Corey
Corey
Its just aluminium tubing.....maybe a hardware store can sell you a small length.......it just has to be the right OD to fit into the plastic fairing holes and the right ID for the bolt to fit through. Length is such that the bolts are just contacting the plastic, but the collars are the main pressure bearers with the bolts tight. A rubber washer under the bolt head does the trick.
Think of them as a piece of aluminum tubing with a washer attached at one end.  The washer is a bit larger than the hole in the belly pan.  The (flat) washer side goes on the inside of the pan and rests on the frame mounts.  Also there is a foam/rubber spacer that attaches to the belly pan on the inside as well.  It provides a cushion between the spacer and pan.
Not too long ago I bought all new mounting bits for the belly pan from Yamaha since I never had the actual parts.  When I had mine repaired and repainted I figured the correct parts were a good idea to mount it back on the bike.
coreyoreo
Quote from: pdxfj on November 03, 2011, 12:11:48 AM
Ok.. got it... that makes sense. Thank you for the help.
Corey
coreyoreo
Thanks Harvey & Rich... I'll see what I can come up with.
Corey
ninjamuder
actually, i just went through this 2 weeks ago on my 85.....if you go to a auto-parts store and get the mounting gromments for a 82-94 chevy s-10 windshield wiper motor, they work great!!...theyre just a skosh thicker than the stockers, so they dont get squashed as badly, and also do a better job of cushioning the plastic, also, they have a steel spacer sleeve in them that lets you bolt them on solid, without over-compressing the rubber.......cost about 2 bux each...fwiw
boscycleshop.com
HOOAH FT. CAMPBELL!!!!
Quote from: ninjamuder on November 03, 2011, 02:52:01 AM
Hey Ninja.... nice find mate..... just the sort of info that makes this a great forum.
ninjamuder
thank you, kind sir!!......my motto is free, or cheaper!!
boscycleshop.com
It's been a long time since I pulled the chin fairing off, I'd forgotten about those.....  I still have it, and it's in great shape. I pulled it off because a good friend lives on a rocky dirt road, and I didn't want to damage it visiting him.
markmartin
Good one!  I'd like to nominate this one for the "Best Cross Reference of the Year Award"
coreyoreo
Corey
ninjamuder
no prob......dunno about the newer bikes, but on 84-85 bikes, these also work great for mounting the upper fairing too.....only 1 of mine were bad, but i had em, so i swapped em all....made a big difference in the rattle/buzz coming off of the fairing!!
boscycleshop.com
coreyoreo
Great!!! I'm replacing my fairing next, also, so I'm assuming I'll need a few more too...
Corey
Ants73
Hi there,
Hoping someone could give me some actual dimensions of the collars etc & the fairing bolts if possible.
Thanks
