FJ 1100 runs on 2 cilinders
Started by gijs, July 24, 2011, 04:59:29 AM
gijs
just did an other 20km test ride and the problem is not 100% gone. sometimes it starts running on 2 cylinders for a minute and then it goes back to 4,
could it stil be the neatral switch or do I need to search somewere else
Quote from: gijs on July 27, 2011, 08:17:07 AM
check the fuse connector from the fuses in the fairing where they plug into the main wiring loom .that's why mine was playing up and loosing spark ect
gijs
checked the fuse and sprayed it with contact cleaner
but that does not help.
the bike start running on 2 cylinders more then on 4 cylinders now
FJ111200
If all the electrics are checking out fine, then to me it sounds like it's pointing to a problem with the carbs, and the main jets being blocked.
Have you had the carbs apart for cleaning or inspection?
gijs
Ive got the craburator boils of and sprayed the jets with carb cleaner
Quote from: gijs on July 29, 2011, 06:35:31 AM
Not The Craw, The CRAW!
FJ111200
Quote from: Klavdy on July 29, 2011, 07:40:58 AM
LOL.
To be honest with you gijs, i think that you might need to take the crabs boils off and clean them out 2 or 3 times for best results.
Take all the jets out and thoroughly clean them and all the orifices.
gijs
next weekend I am going to take the bike apart to check out every thing.
I will let you know if I find something
MyOwnFJ1200
Quote from: Pat Conlon on July 24, 2011, 05:07:19 PM
Quote from: gijs on July 24, 2011, 03:56:29 PM
does anyone have a wiring diagram.....
I can show where to get one.
On the back page of all the FJ owner's manuals, is the wiring diagram for that specific model....Don't have a owners manual?
Down load one free from Yamaha:  http://www.fjowners.com/index.php?topic=3483.0
I have swapped the 2 coils and then I get a spark on cylinder 1 and 4, and otherwise it sparks on 2 and 3,
i have tried an other coil and that doesn't help.
If it sparks on 1&4 and you swapped coils and now it sparks on 2&3, then you have a bad coil.  Something must be wrong with your replacement coil.
Why do you think that it is the wiring when the circuit for coils 1&4 and then the circuit for coils 2&3 work correctly when the right coil is used?
Cheers!   Pat
i would agree with pat on this . another question i have is have you changed the oil filter latley if so maybe the wires from the stator got pinched in the housing????
Brian
JFox
What was the ohm reading on 1&4 nd 2&3 plug caps?
gijs
I got the engine out and I am think I Will solder all the wires to the connectors so that Will be 100%
I  will keep you guys up to date if make any progress
Sideburns
If I can help, let me know. I'm actually able to pop by for a look.
Old wiring is a B...
