Need Help! Float Height Adjustment!
Started by Lotsokids, July 16, 2011, 07:36:17 AM
billwest
Thanks Pat, I hadn't seen that page.  I had however looked at the tutorial on the forum.
I actually measured mine at point "A" originally, and the carbs promptly overflowed, hence my search.
All is good now.
Bill.
Sold it!
chiz
Hi
  Does any know if there is an image anywhere that shows the fuel level in the carbs using the clear hose method? I would like to try adjusting it this way.
Thanks
Here's some info from our XJ brothers:
http://www.xj4ever.com/setting%20fuel%20levels.pdf
From U tube: https://www.youtube.com/watch?v=PHuB1lyagKM
Check fuel levels with the engine running (vacuum petcocks open or fuel pump running)
MOTOMYSZOR
I don't know if it is any help but I made a "float gauge" out of a piece of aluminum sheet. Now I can make sure that both floats are level and parallel (will not rub against the float bowl). Disadvantage it's a fixed height of 22mm for me.  The narrow legs rests on top of the carb bowl flange bump.
theLeopard
1992 FJ1200
