Clockwise or counterclockwise
Started by FJTillDeath, July 15, 2011, 07:16:33 AM
Quote from: billwest on July 18, 2011, 06:05:02 AM
Quote from: FJmonkey on July 15, 2011, 08:31:17 PM
Maybe you should just flip it over and reverse any directions already provided.....
Don't forget about the coriolis force - things go the opposite way in the Southern Hemisphere ..............
No.
They don't always.
billwest
Well, what do you know........
Another "fact" debunked.
Sold it!
FJTillDeath
flips
:rofl: :sarcastic: :rofl:
Stay rubber side down.
Matt
My FJ is running like it should now after my initial problems with the fuel pump but it sounded like it was going to implode at idle - rpm was closer to 500 than 1000!  Anyhow, being in New Zealand I turned the bike upside down (took ages to get the windscreen off and rig up a gravity feed from the removed tank to the pump) and whoever said that you can reach that nut with your hand must have very small mitts...  I ended up asking the 2 year old next door to reach in and turn the nut.  The hospital advises that the burns will heal in a week or two and his mother says it wasn't entirely my fault.
It does run now very smoothly at idle.  The only problem is I can't turn it back over on to its wheels on my own and the neighbourhood mothers have banned their kids from helping me anymore.
Ideas?   :shok:
All jokes aside it was a pretty easy job, why on earth the idle screw is there I don't know, if it wasn't for the forum I'd never find it.
Many folk recommend adjusting the idle speed with a screwdriver, which is still a bit fiddly.  I find the easiest way (on a hot motor)  is with a gloved hand, either my winter riding glove or if at home a riggers glove (not too thick). You can also do it this way on the road in about 4 seconds once you've done it a few times and know exactly where to reach and what to feel.
Quote from: ribbert on August 28, 2011, 04:54:58 AM
I used to adjust mine with a screwdriver...Till I bent the adjusting screw!!! Bent it back straight sometime later when I had the tank off. Now I reach in with a glove on. I could jimmy up a tool using a right angle attachment. Too much effort for not having to adjust it very often.
