mounts
Started by mrbreeze, June 08, 2011, 12:23:45 PM
mrbreeze
i was wondering if anyone would be willing to take some detailed pixs of their bag and top case mounts. i think i'll try and fabricate some thanks
reid
The behinder I get The faster I go
craigo
Quote from: mrbreeze on June 08, 2011, 12:23:45 PM
reid
Reid,
What luggage are you using?  Givi or some other one?  If it's a Givi wingrack your looking for, I can do that for you.  Just exactly what details are you needing?
CraigO
CraigO
90FJ1200
mrbreeze
CraigO
right now just in the begining stages. found some really nice bags and top case. want to do alittle custom job and see how it turns out. needed a place to start. any help at all would be greaet. thanks.
reid
mrbreeze
any pixs of how they are mounted, lengths ect. would be great. just need a starting place
MrFox
I've been kicking around an idea of removing the grab rail and fabricating some sort of top case holder that replaces it.  Could also double as a passenger back rest.  It wouldn't be too difficult to make it.  I'm not sure if it could actually support any weight.
mrbreeze
I'm beginning to find it hard to believe that no one out of all the members could come up with some pixs or measurements or anything at all. Not being mad or indigent but still.
Quote from: mrbreeze on June 15, 2011, 03:42:30 PM
Waaah...      :blum1:
Fairly sure at least some of these are posted in another thread, but what's a little more bandwidth, right?  :biggrin:
mrbreeze
sorry Randy didn't want to be a whynner but I didn't find any on other posts. thanks that gives me a starting place
carsick
Erm, indignant? Still working on a joke for indigent though...
Quote from: carsick on June 15, 2011, 10:26:11 PM
I figured maybe indignantly indigent, else he'd just try to buy the mounts... maybe Kurt has some he's holding back.    :biggrin:
mrbreeze
maybe not buy the mounts cause not going to use givi bags hmmm maybe anthropormorphic
markfj
Hey thanks, those pictures are going to help too.  I had the mono-rack on but it cracked both turn signal tabs after many years.  I just re-welded them back on this morning and am planning on mounting the wing rack tonight.  I only have the top case but I think I can use the side mounts to support a set of soft bags I have until I can score a decent deal on some side cases.
So many projects - So little time
StatDoc
Most of the other vintage sport bike nuts I know are engineers as well (sorry, I'm a simple IT geek / statistics guy) - perhaps I can re-state the question - does anyone have an AutoCad or SolidWorks rendering of a bag mounting system for an FJ1100/FJ1200?  I'd like to mount some BMW hard cases on my '84 FJ1100 - if no one else has renderings I'll take some measurements, do some calculations, hit AutoCad for a couple of hours, feed the CAD to a local machine shop and publish the results (pics and .dwg's).  However, being the lazy bastard that I am (hell, it took five stabs at my dissertation) I'd rather that someone else had created the .dwg files ....
I fit a Rentec (?) for the top case, and a genuine Givi rack from a ZZR somethin-r-other for the sides (drilled and tapped the grab rail otherwise it was a bolt on).  I use Givi knock-offs but real Givi stuff would fit too.  Top case works excellent as a back rest under full kookaloo...  Does this help?
and in action:
'93 Yamaha TDM850 (x2)
'06 KTM 200XC
'43 BSA WM20
candieandy
Sorry i don't have any pictures, but i bolted a set of custom bag brackets i made onto the tail. You know im not using them anymore if you want them( you have to pay shipping). they are two piece brakcets. the small piece mounts inside the rear fender and can't be seen without looking up into the fender. the second parts bolt to it and hook into the upper strap loop. its ugly, but really strong and could be changed to fit hard bags. I currently have some soft bags on it.
HAUI
