Help Please! What goes here?
Started by EskimoDave, May 01, 2009, 03:32:24 PM
FJ1200W
Great forum, I just noticed the left hand side 90149-08255-00 is missing, now I'll check to see if the head snapped off.....
Anyone have the specific replacement size?
8mm (or resized to 10mm) and how long?
Many thanks
Columbia, Missouri
USA
balky1
Last year I noticed I am missing that large nut on your pic and a nut from a center stand bolt. Seems common to get loose? I check them now and then from that point. Standard socket fits on them. Just enough space. But if you put larger bolt, I am not sure if it will fit.
I often notice some bolts missing or coming loose. Most often the nuts on the chain tensioners, although there is a nut and a counter-nut. One of the bolts from the mufflers came loose. The list continues.....
Just check them periodically.
FJ 1100, 1985, sold
FJR 1300, 2009
FJ1200W
Update: I opened one of the totes of spare FJ parts, and there was a rear master cylinder in there, with the mounting bolts attached.
As luck would have it, the bolt fit perfectly.
:good2:
Columbia, Missouri
USA
