chassis number? where is it?
Started by fiatpandaman, May 09, 2011, 12:29:48 PM
Quote from: jvb_ca on May 10, 2011, 02:58:06 PM
I like the looks of the horns Ed. What are they? Also the braided lines with the anodized fittings. :good2:
Cheers...Jake
Jake, the horns were nothing special, they've already gone by the wayside.  Think OEM horn, but quieter even after the relay mod.  Now working on the Wolo Bad-Boy, claimed at 132 db.  We'll see ...  Doesn't want to fit, never mind the claimed SPL.
Brake lines are Galfer.  Work nice, but not worth the money.  IIRC, the are -2 AN; the local shop doesn't work "with crap that small".  Find a local shop to build exact lines for you, they'll save you some money, I'm sure.
macca1963
Ok i know this is a old thread but i had the same problem and fortunately have found the number but i had it had been painted over when new so was unfindable [ is that a word] until i received help from a local facebook post
The frame number was indeed stamped on the right side frame under the fairing , right opposite the head stock , i could not see anything and took to the area with , paint stripper, and emery cloth and like magic the number appeared
i will post a picky shortly
cheers
Bikes
1985 Yamaha FJ1100
1979 Honda CB 750
2007 Triumph Sprint ST
