XJR rear wheel swap?
Started by fb747, May 09, 2011, 02:48:04 AM
Seanextra
This is the Wheel , Trial fitted it and it sits nearly hard on the disc side with 26mm gap on the sprocket side looks like it will need some trimming around the carrier and about 13 mm off the disc bracket and might come in pretty good alignment with a off set front sprocket this is just a quick look not much time lately busy with work! Ill let you know how i go or if anyone else beats me to it or has done it before please share your experience!
how did you go with the wheel swaps
