Reserve switch. What does it actually do?
Started by wakdady, April 23, 2011, 10:42:47 PM
wakdady
I did a search and read that it was a simulated electronic reserve. but what the hell does that actually mean?
further search mentioned something about the petcock doing something as well.
i was low on fuel the other day and flipped the switch not knowing if it really did anything. when i was cleaning out my tank i also noted that there is nothing electronic about my petcock. just a simple "on" "off" valve for when you remove fuel lines.
so if the petcock doesnt do anything. What's going on in there?
tqmx1
On the fuel pump bikes it shuts off the pump so you have to go to reserve to start the pump again. Sounds screwy but that's YAMAHA for you.
WS
The fuel sending unit gives a signal to the black box which turns off one ignition coil. The bike starts running on two cylinders and it feels like you are running out of gas. By switching to reserve you turn on the coil again.
wakdady
At what point does that occur? Right when the light turns on? Or after its been on for a little?
Thanks for the proper info btw!
WS
It happens after the light turns on. You still can go for a while with the low fuel light.
Quote from: wakdady on April 24, 2011, 12:45:11 AM
.....the point when your bike starts running on 2 cylinders COULD BE exactly when you don't want this to happen... Like when you're passing a string of RV's on a uphill grade with opposing traffic coming at you....Yea, that is exciting.
With a working fuel gauge, low level light and a trip odometer, do you really need a reserve switch?
chapindad
Thanks for asking the question.  I have be trying to figure it out myself and kept forgetting to ask myself.
1987 Corvette
Travis398
What year FJ are we talking about?  They're not all the same you know.
tqmx1
Let me change my statement. The 89/90 cut fuel pump power the 91 and up just might shut down a coil.
weymouth399
I'm glad my 86s works. The light comes on just as I need to turn reserve on. So far so good 5000mi later and it still works, tried it the other day. :dash1:
If it's there, it will be hooked up. It might save me a dumb shit of the day award, I get enough of them lately thank you.
Bob W
84 FJ 1100
86 FJ1200
89 FJ1200
5  FJ POWERED race cars
76 LB80 Chappy
93 KX500 ice for sale
00 KX500 ice/dirt
04 KDX220 dirt for sale
04 KX500 ice
08 KLX450 ice/road
72 CT90x2 for sale
LA Mike
Quote from: tqmx1 on April 24, 2011, 09:17:07 AM
I have also wondered how this switch works, I know some have posted they have disabled this function. I have a '89 so what needs to be done to the switch/bike to disable it?  I normally just watch my miles to know when I'm low on fuel.
Quote from: WS on April 24, 2011, 12:32:16 AM
This is INCORRECT.... on all years FJ(except 84 & 85), the fuel flow is shut off, 86/7 use a solenoid at the petcock, 88-on shut off the pump.....
Kopfjaeger
Quote from: Pat Conlon on April 24, 2011, 02:28:52 AM
cool.... im guessing i found my flaw.... chuckles... my light comes on but its only when it irratates me that i hit my res switch.... havnt had it drop out or cut out on me..... only once when it was dead empty and within the last 10 meters ( 30 odd feet in old speak  :blum1:) of the servo. agree with ya pat... watch the little numbers go round and know the mileage/kilometerage is always good.... also as my fuel needle has popped itself all the way round to the other side of "E" and i couldnt be bothered fixing it for the gazillionth time..... so im just a numbers guesser now..... interesting read this to know what happens i actually thought it just switched off the pump and turned it to gravity/ vacuum feed
Quote from: RichBaker on April 27, 2011, 07:38:37 PM
Agreed!
Quote from: Kopfjaeger on April 27, 2011, 07:52:04 PM
Neil, I have a fuel gauge here if you want it........its still on the right side of the stop....... removed it when I installed the Acewell dash.
