ok i know this is a fj forum but im having a problem with another yamaha
Started by irishluck, April 13, 2011, 12:35:55 AM
Kickstand switch, clutch switch, killswitch.  Probably something stupid.  Check for power at appropriate places.
irishluck
I know we have checked the kill switch. That one is working fine. Can the kickstand switch and the clutch switch or something really cause it to have no spark at all? I never did think about that, i mean i know the kick stand switch when put it gear and is down that it will die when giving gas and letting off clutch.
irishluck
Yea, start at the sensor and follow the wires back to the closest connector. Unplug the connector.
You now have 2 plugs, one plug and wires goes to the sensor... and the other plug and wires goes to the ignition.
With me so far?  Follow this carefully....
On the plug that goes to the ignition, there are 2 prongs in that plug, one for each wire, bridge or tie those 2 prongs together with a piece of wire.
Follow this carefully, or a loud popping noise will come out of the engine.
Quote from: Pat Conlon on May 19, 2011, 05:47:41 PM
We need a Smiley for this, plugging his ears with his fingers, waiting for "Kaboom".....
irishluck
haha
al-right ill give that a try tonight then. I haven't had time to do anything all week been working to much but ill give it a go tonight
irishluck
i bypassed both sensors, no spark still, so ignitor?
or should i check something else
irishluck
carbs are spotless, new jets, needles, everything.
but what would that have to do woith having no spark?
irishluck
so i turned the bike on. Just in the on position. And checked the output power of the ignitor, its only getting 6v, shouldn't that be getting 12v?
