86 fj vacuum line ?
Started by guinness1200, April 12, 2011, 05:50:16 PM
guinness1200
Can anyone tell me where the vacuum line from the second carb on the left intake boot is supposed to be attached.    Thanks in advance, Eric
tqmx1
It's been a long time one of the hose's goes to the fuel valve and the other runs down to the ignitor unit on the left side of the bike.
guinness1200
If that hose is not hooked up would it cause the bike to act like its loading up on fuel? I am not really firmiliar with these bikes yet.
Ratchet_72
It'll just be a huge vacuum leak until you hook it up to either the fuel petcock or the ignitor like Kim says.
Jason Cox
2000 Honda CBR1100XX
1977 Ironhead
Sacto, CA.
guinness1200
I plugged it off so it not a vacuum leak, it is the one that runs to the ignition unit. What does it control on the igniton unit?
Ratchet_72
Quote from: guinness1200 on April 12, 2011, 08:57:19 PM
Ignition advance I believe. I'll let someone else chime in as my noodle is tired at the moment.
Jason Cox
1977 Ironhead
Sacto, CA.
on the 86 the 2nd line runs to the ign unit on the left side next to the battery. there is a little fitting it plugs into.
if it is not hooked up your bike will run like crap. has to do with the timing adv.
plug it back in.
guinness1200
I am going to check it out after work tonight and see if it makes a differance. I think I am going to pull the carbs and cleanthem as well.
cleaning the carbs is always a good idea.
watch out for the petcock elbow as you pull the fuel line off the tank. It can get loose and fall off later while you are riding and start a fire.
most of us have safety wired it in place.
after you have the tank off take a picture of your fuel line routing . the 86 is very picky about it and if you don't put it back like it was you can have fuel starvation problems.
good luck.
moparman70
Ditto on the routing of the fuel lines -- do it right as it can also rub on the tops of the carbs or if the bends are not correct get cut over time and then you will have a nice fuel leak.  The original fuel lines are very prone to this -- I had two cuts appear right at where it connects to the fuel petcock.  If  you have replaced them 'by the foot" lines it will be less prone to the cuts but I also found the thicker the hose the harder it was to achieve all the loops.
steve
guinness1200
Thanks guys! Mine actually has the routing picture on the air box.
Quote from: guinness1200 on April 13, 2011, 01:32:30 PM
double check it some of those were a misprint.
srutherford
i think that answered my question. now how to figure out the correct roughting. i am for sure starving for fuel
