My bracket broke :(
Started by Carterc, March 17, 2011, 01:55:21 PM
definitely have to look out for each other....  :good2:
Our network worked pretty good when Henry had his deer strike on the southern part of skyline dr also.
good karma goes a long way....  pay it forward whenever you get a chance.
Yea, I remember that, what's it been, 10-15 years now?  What a mess. Didn't he cut the deer in half?  Even though hurt, he was still very very lucky.
Those bloody pictures....aggggghh.
Carterc
holy cow, well im thankful i stumbled across such a great group of people with an ad-less website!
(and plus i like all the smiley faces...those are fun :yahoo:)
1986 FJ1200
Yamifj1200
"Our network worked pretty good when Henry had his deer strike on the southern part of skyline dr also."
Remember Nobby's ignition problem on his 89 FJ several years ago. Calvin took off of work, went and got his trailer, picked up Nobby and his bike. He took him home and changed all mater of parts, fed him and let Nobby ride his 97 to boone the next day. Once Calvin and Nobby's bike showed up in Boone a pit crew of folks had it running in minutes. I'd like to see another group more willing to help a brother out....
I remember a few years ago when Marsh offered to send me his fuel pump when mine died the day before I was to ride to Indy for the first ever Moto GP races.
Great folks indeed!!!!!
Eric M
Carterc
i cant find it in my clymers manual, can i just take the bracket off by itself? or do i have to take other things off while its on a center stand or something?
thanks for the help!
also, what do think this was for?
1986 FJ1200
You can take your right side bracket off without removing the swing arm pivot bolt. Just take the nut off. (Note: it's different to remove the left side bracket, you have to remove the swing arm pivot bolt)
IOW everything should just unbolt and the bracket will come off
You need to unbolt the rear brake master cylinder (just unbolt and let it hang, don't disconnect the lines) and stoplight switch and remove all the NOS switches and pressure gauge
I suspect the red NOS switch and light on the left side is for a bottle heater.  Cheers
Quote from: Pat Conlon on March 19, 2011, 11:30:43 AM
I was going to guess either the smoke screen or the oil slick...   but Pat is probably right.
Carterc
Quote from: Marsh White on March 19, 2011, 12:13:19 PM
hahaha i hope thats what it is!!
1986 FJ1200
FedEx tracking# 796889975370 arriving there on Wednesday afternoon. Cheers.
Carterc
1986 FJ1200
Scooterbob
I was equally curious as to what all those switches are for.  Three switches and a guage?  I'm guessing the same as Pat.  Interesting place to put them though.
-----Bob G.-----
Carterc
yah i really have to reach to get them, and why would you take your hand off the throttle to hit the nos? isnt that counter productive?
1986 FJ1200
Scooterbob
Exactly. I would never run NOS on a bike, but if I did I would put it a lot closer. Maybe it was l.e.d. lights?
-----Bob G.-----
Heh heh, no Chris you don't reach down.
When the giggle gas hits you don't even think of taking your hands off the bars.
The bottle heater on the left is used intermittently it draws a lot of wattage, the gas and fuel switches on the right (assuming a wet system) activate the system and are set to "on" before the run. The gauge reads bottle pressure.
There should be a button on the left handgrip which fires the system. Don't see it?  I bet your horn doesn't work huh?
The horn button is the most convenient button to hot wire for a NOS system.
Carterc
THATS WHY MY HORN DOESNT WORK!?!? :dash2:
1986 FJ1200
