Standard Carburetor intake manifold restriction
Started by Bozo, February 24, 2011, 05:50:26 AM
Bozo
Quote from: weymouth399 on February 24, 2011, 03:50:17 PM
Bozo
I have some of them, if you can't find any around.  Where ever you are.
Bob W
Weymouth, are the manifolds you have in good condition? If the condition and cost is ok I'll take them off your hands. Email me - jwitt85@gmail.com
Quote from: Bozo on February 26, 2011, 07:36:32 AM
Mark, yes you are right, its time I read the section about clutch improvements. I assume you are talking about changing the clutch spring plate setup for an APE spring and hub type?.
I'll be going on a sunday morning run tomorrow, I'll let you guys know if the fuel economy improved (with some luck).
to increase your spring pressure simply add another stock style spring on top of the one already there. oddly enough the clutch spring for a fjr1300 is the same as the fj1200 only less expensive.
Bozo
Mark, thanks for that information, sounds like an inexpensive fix.
Bozo
Thankyou for that information, I have replaced my manifolds with the 36Y, and the bike goes like the clappers (especially after the restrictions).
Quote from: racerrad8 on July 17, 2011, 03:37:51 PM
Here are the 36Y large bore replacments; http://www.rpmracingca.com/proddetail.asp?prod=Carb%3AIntake
