neutral safety switch
Started by karl61, February 17, 2011, 04:03:29 PM
karl61
thanks Dan -
Bleeding a Clutch NSR Tech
they went over some basics here.
I will check out the tool you recommended.
I disagree with the method the guy in the vid used a bit.  I have found that with some clutches/ brakes the nipple valve must be closed before (hopefully just before) the lever hits the stop.  For whatever reason, it seems to provide less opportunity for air to be re-introduced into the system.  But that may just be me being anal.
Anyway, it's roughly as easy as demonstrated there.
Good luck!
