silencers
Started by josh vesey, January 03, 2011, 04:49:22 PM
josh vesey
what silencers do most people fit to their fjs? im getting new stainless down pipes and collector box. can you use silencers made for xjr 1200s ? and so i was to fit a pair of new silencers would i need a link pipe to go from the silencers to the collector box?
Josh,
There are almost as many choices of silencers as there are members here.  All depends on what is/was available and at what price and looked or sounded good when the need to replace OEM was made.
Yes, you can certainly use silencers 'intended' for the XJRs.
With all these, if it is not expressly intended for the particular year FJ you have, you may need to also get or make a mid-pipe to join the silencer to the collector.  You may also need to make or modify the rear hanger as well.
josh vesey
thank you for your help, i am having trouble sourcing such pipes that connect the silencers to the collector. does anyone have anyone in mind that may be a good supplier??? thank you
Usually the manufacturer of the end pipe will have the link pipe available, though not always.
An overlooked option is to ask at the local muffler shop, just specify that it has to be stainless.  Usually they like to do something a little different from the usual endless crap on cars. :)
mz_rider
Quote from: josh vesey on January 03, 2011, 04:49:22 PM
Josh,
I found this site with various FJ silencer options.
http://www.echappementmoto.com/IMAGES/echappementmoto/YAMAHA/FJ%201100-1200/echappement%20moto%20YAMAHA%20FJ%201200.php
I had a complete MOTAD system on my old FJ the various parts of which (ie downpipes/collector/silencers) were compatible with the original parts. On my new FJ I have a pair of black MIVV silencers that look like original and fit onto the Yamaha collector box. Both of these are as quiet as the original equipment.
Stuart (Glasgow, Scotland)
Quote from: josh vesey on January 04, 2011, 05:43:14 PM
Here is another interesting option from the UK:
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=150542027299&ssPageName=STRK:MEWAX:IT#ht_630wt_906
The pipework uses the original header pipes, and replaces the collector and cans.
I asked this question:
Dear sandybikespares,
Hi folks.....just wondering if this system is available without the can?
ie. just the 4-1 part of the system?
and their response:
Hi, The pipework is £149.99, many thanks
- sandybikespares
josh vesey
wow well thank you for all the help folks, i like the offer that sandy bike spares do that looks good! thank you!
jack02
Quote from: josh vesey on January 05, 2011, 03:05:28 PM
Yes, I got the collector/silencer combo (see my post in this section titled "4into1 exhaust") and can heartily recommend it. Very very good!
fj1250
I've done a 4:1 using a Supertrapp head pipe and grafted a YZF1000 titanium muffler.
Makes the power of a header without the noise.
I've found that stealth can be a good thing when your flying low.
Mike C
Yeah, I had XJR 1200/1300 mufflers on one of my FJ's,(A 1989 3CV)there's a write up and all that somewhere either here or over on the other place, fucked if I know where but.
They looked pretty good and sounded great once they had been opened up a bit.
