Bike will not start when jumped but will start when bumped but no head light
Started by scapello, April 07, 2009, 10:35:40 PM
Not to split hairs here, but I think Dan meant to remove the top 2 bolts on the subframe, not the swingarm.
scapello
Steffen
'76 CB750Four
'74 RD250
Quote from: simi_ed on April 09, 2009, 11:00:34 AM
Correct! My Bad.  Although, for as long as I've tinkered with bikes, I've reversed these two parts, when not thinking explicitly about it.  'Sub' meaning below, belongs below a 'high flying' sounding part like a "swing arm"...    :pardon:
Good advice Dan, I think you meant sub frame bolts?
Quote from: Dan Filetti on April 09, 2009, 07:45:33 AM
  Regarding the air box removal, if you remove the top 2 swing arm bolts, and loosen the bottom two, the swing arm will pivot down on the bottom 2 bolts which in turn provides you the crucial little bit of clearence needed to remove the air box, and the carbs as well...
FYI.
