Full Fairing for FJ??
Started by Kopfjaeger, December 09, 2010, 07:25:52 AM
tim95621
I agree
I just haven't found the chin scoop at a price I thought was fair. Plus my engine has been "uglied up" a bit. So, until I have time to tear the bike down for paint...
Tim
86 FJ1200
Citrus Heights, CA
Quote from: Kopfjaeger on December 14, 2010, 09:01:35 PM
wow thanks paul. thats heaps of info... i may end up trying to source one over here for the rainier months.... i dont think summer over here and traffic will be friendly towards it.... not unless i bite the bullet and mod with bigger oil cooler and a thermo fan.
No need to get a bigger oil cooler and thermo fan mate, you can lane split in Australia.
paulfj03
Quote from: racerman_27410 on December 16, 2010, 04:12:09 PM
Quote from: tim95621 on December 16, 2010, 03:38:59 PM
Well I stink at these silly little digital cameras. I guess I really am old now.
The full fairing I have is Identical to the one shown above on the 1100.  I would kinda like to mount it, the bike just looks like it's missing something.
The front mounting hole is directly above the point where the lower frame cradle mounts to the frame, about 1/2 inch out. The rear hole isn't near anything. it's just out in space around the oil filter area.  I think even a verbal description of where the brackets were, and what they bolted to would help me.
Tim
IIRC ...i believe the mounting holes on most full fairing are similar to the one i got from T Roy... they used longer engine cover bolts/frame bolts (which ever ones line up with the fairing holes) along with different length brackets ( bent flanges on either end ) to hang the fairing.
yes, that is how my fairing is mounted... the 2 front upper mounting bolts go into the stock brackets, and the 2 rear lower mounting bolts go into the stock downtube brackets underneath...then another mounting bolt on the right side is an extended bolt with spacers that bolts into the top of the clutch cover.  On the left side , another extended bolt with spacers replaces a bolt in the slave (I believe).  So there are 6 mounting bolts total.
paulfj03
Quote from: jvb_ca on December 16, 2010, 02:36:24 PM
Quote from: paulfj03 on December 14, 2010, 08:11:23 PM
ok, I was able to obtain a couple of pictures from Spec 2..They still offer the 1100 lower fairing, but not the 1200.  I assume they just have 1100 fairings left over in stock. The picture of the 1200 fairing on the 86 is not the same as mine and I'm not sure if they are one piece or not, where as mine is just one piece. The lower for the 1100, at Spec 2 , sells for $299.95.
86 1200
Hi Paul. This pic of the fairing on the 86 appears to be a Targa fairing. I have a brand new, never mounted fairing hanging in my garage. I never got the mounting brackets with it. I have mock mounted it a couple of times, but fit is not the greatest. The sides hit up against the distributor cover/crank case. It should have cutouts on it like your 1100 fairing has. Paint color and finish is very good though.
Cheers...Jake
Hey Jake,
Thanks for the info..however, that picture of the 86 1200 was sent to me from Spec 2.  I did send them a picture of my 86 lower fairing to them to see if it is one that they sold in the past, as it is similar to that in the picture of the 1100.  I havn't heard back from them yet....
my 86- rear view
This picture shows the clutch cover mounting bolt for the fairing.
carsick
Quote from: SlowOldGuy on December 16, 2010, 06:40:13 PM
a big appeal of the FJ is that beautiful engine hanging out there to be admired.
Exactly. Those liquid cooled bikes deserve to be covered up! In looking back over my bike pics I realized half the pictures are of the engine and pipes, I do love to see the mechanicals on display.
1TX650
Quote from: Kopfjaeger on December 09, 2010, 07:25:52 AM
ok i like it ive seen one and i want to know more. mainly heating and cooling, theres a guy on f/book and his looks nice if you like full faired bikes. he says the only drawback is access to the engine and it does get a  bit hot. you guys seem to know what the wing wong on the gooses bridle is for as far as fj is concerned  i have an idea it would get hot as buggery here in ooostrayliea so maybe thermo fans and bigger oil cooleer. its not a cert but i want to keep looking in to it. From what i can see looks like original top half and instead of bellypan it has a full bottom piece that joins up to top. not a 3 part one like the kwaka ( top to chin scoop and side panels then belly pan)
Got one on my 1986 and live in Iowa.  It's mad by Lockhart Phillips originally and I've only seen a few in pictures.  Ducts air just fine through my scooter but I don't see many 100 F + days here in the midwest.  I'd say at the speed you cruise heat build up shouldn't be  a problem for the engine but it might make your legs a bit toasty :o).
"Watch This..."
Woodsman
Have the same one but just got it back from the painter and wont be back on the bike for a while. I know what people are saying about wanting to see the engine but it's simple to pop it off for a different look . Any chance you can stick up a pic of yours fully dressed? Go on, go on, go on, ya will, ya will, ya will. :good:
"Man who chops his own wood heats himself twice"
87 fj1200,TBS,Daytona 900,NC30.
Seanextra
I bought this single seat fairing and it matches up great for the tail section for my 3CV but it was NOT CHEAP they also do full fairing for the 88-91 3CV also not cheap but well made. Gimbel of Germany . Not easy to find but im sure someone else might be able to link you with a supplier i just found these on ebay.
86 Single Seat
http://www.ebay.de/itm/FJ-1100-FJ-1200-VERKLEIDUNG-GIMBEL-SITZBANK-BURZEL-RENNHOCKER-MIT-RUCKLICHT-/380523578702?pt=Motorrad_Kraftradteile&hash=item5898f9054e
86 Lower Fairing
http://www.ebay.de/itm/FJ-1100-VERKLEIDUNG-GIMBEL-UNTERTEIL-UMBAU-ZUR-VOLLVERKLEIDUNG-GUTER-ZUSTAND-/380523576426?pt=Motorrad_Kraftradteile&hash=item5898f8fc6a
Steve_in_Florida
Quote from: Seanextra on December 12, 2012, 12:25:53 AM
I usually don't care for the full fairings, but *THAT ONE* on *THAT BIKE* looks GREAT!!! Very nice!
`90 FJ-1200
`92 FJ-1200
IBA # 54823
paulfj03
Quote from: 1TX650 on December 09, 2012, 06:44:34 PM
By the looks of your avatar, that lower fairing looks like mine. Lcokhart Phillips?
Cool. Yes, post up a picture or 2 if you can...
paullyd9f3
86 Single Seat
86 Lower Fairing
Any idea if the 85-86 are compatible with an 87? Im having a really hard time finding the lower scoop/fairing. I did reach out to Gimbel so hopefully they get back to me soon and can help me out!
