Corbin seat care
Started by Mark Olson, November 22, 2010, 01:14:05 PM
With all the products available for leather , what do you use to clean and beautify your corbin seat?
Mark,
My corbin seat cracked like a mofo - the plastic covering got very brittle after years in the sun and I ended up gluing marine vinyl to it - turned out better than it sounds (fortunately).
Anywho, leather has always benefited from a good going over with 'saddle soap' available from your local horsey store. It cleans and feeds all in one. I've used it on my jacket and riding trousers with great results.
Travis398
FJ Flyer
I've just used some leather cleaner and Meguir's (I think) leather conditioner.  Depending on what pants you're using, it can get a bit slippery for a while.
Chris P.
'16 FJR1300ES
'87 FJ1200
'76 DT250
Wear your gear.
What ever you do DON'T use Armor-all. If you don't slip off the back doing a Kookaloo moment then you will crush your Jewels next time you grab the brakes.  :ireful: And the seat cover will fail quicker than putting nothing on it.
Lexol leather cleaner then, Lexol leather conditioner. Available at Pep Boys, etc..   HTH  Pat
markmartin
Quote from: FJmonkey on November 22, 2010, 07:37:27 PM
Same goes for 3M Leather and Vinyl Restorer.  I'm a fan of 3M products, but this stuff will have you sliding around like Pledge on hardwood stairs, especially when wearing textile riding pants. Not good.  I've used Duragloss 221 Leather conditioner.  Seems to work well but similar to what FJ Flyer said about Mcguires--it's a bit slippery for a while.  Saddle soap works well if I've got time to let it dry.
My 2 cents
SlowOldGuy
BICK 4
Should be available at any place that sells boots.  Been using it for 30 years on my boots and works great on the Corbin.  Will NOT make the finish slippery.
Armor-All is absolutely the WORST product I have ever used.  The few times I used it, it drastically accelerated the rotting of whatever it was I was trying to protect.
thanks for the heads up , I will treat it accordingly . :good2:
SILVERGOAT
I use Neutrogena hand lotion. It is NOT petroleum based and is fairly stiff so it does not run all over when spreading it over the seat. I use it after each wash and sometimes I'll put it on the night before a long ride and let it soak in. It does not make it slippery and seems to keep the leather soft. It also has seems to offer some water repellent quality and has a pleasant smell to it . The best part is its fairly cheap and can be gotten anywhere and comes in many different size bottles such as travel size. I also make sure to rub it in really well in the seams. Hope this helps.
It's easier to beg forgivness than ask for permission
Quote from: SILVERGOAT on December 08, 2010, 07:20:58 AM
Wow! you might get a few lined up to volunteer to be your seat... :shok:
Quote from: FJmonkey on December 09, 2010, 09:08:17 PM
Well, maybe at a WCR...        :bomb:
We're NOT having a WCR in Hollywood this year!  :ireful:
Whoa.. steady now , we are talking about corbin seats .
The lanolin in neutrogena is the active ingredient for the leather. not a bad idea. :mail1:
"IT RUBS THE LOTION ON THE CORBIN SEAT, IT DOES THIS WHENEVER IT'S TOLD"
TRoy
Quote from: Mark Olson on December 10, 2010, 01:48:23 PM
PUT THE FUCKING LOTION IN THE BASKET
Peace & Love
86FJ 100K+
07Burg650
15Downtown300
