1989 FRONT WHEEL TO 1985 FJ1100 BOLT ON OR?????
Started by COLDFJ, October 09, 2010, 10:53:28 AM
COLDFJ
Hi all...what year did yammy come out with the 17 inch 3 spoke front  are they all the same  for all the years   will it bolt up to my 1985 fj1100   how about the brakes?
Travis398
89' got the new wheel, the discs are bigger (and different bolt pattern) won't work on older forks.
88 got the new wheel, but it wasn't imported to the US.  88-90 is functionally the same bike.
Travis398
Yes Andy is right, I keep forgetting we are the only ones deprived from the '88 FJ's.  And that they actually exist :pardon:
My first post wasn't very specific, so i was hoping someone would refine my points...  (popcorn)
Travis398
COLDFJ there is some pretty good info here also  http://www.fjowners.com/index.php?topic=1208.msg9078#msg9078
But beware of the sickness..........
Quote from: COLDFJ on October 09, 2010, 10:53:28 AM
Later wheels will bolt on to your '85, however the brakes will not.....rotors use a smaller bolt pattern, and caliper mounting is different.
You would need a set of '88-up lower fork legs, and 88-91?(before ABS) front rotors.
Then you are welcome to my '90 wheels and front calipers. the rear wheel will bolt right on with no changes. :good2:
COLDFJ
Thanks for all the help...so if  i buy up some 89 forks and  triple tree.. a complete 87 88 fzr 1000 front  wheel complete whith rotors and calipers hoses and master  it should all boltup or?   which axle  fj or fzr?
Quote from: COLDFJ on October 10, 2010, 02:38:22 PM
FZR1000 wheel will bolt to 88-up forks with no problem......The FZR rotors will not work though.They are slightly larger diameter than the FJ rotors..FZR calipers were mounted slightly higher....You need 88-up(non ABS) FJ rotors.You don't need a triple tree though. The '89 forks will fit your early triple tree.(actually all you need is the lowers. Your early upper legs will slide right into later lowers)
I used my FJ axle, and all my FJ spacers(except the one inside the wheel between the bearings)
Easy bolt-on' but you have to use an '87 or '88 FZR wheel......they changed the axle and bearing size after that.
Quote from: Firehawk068 on October 10, 2010, 03:44:39 PM
Those rotors were used on a number of models. They were used on fzr 600's and TDM's , just to name two.
