School me on the GSXR rear wheel mod
Started by wakdady, October 02, 2010, 12:04:54 PM
billwest
Yep, 17 x 5.5 wheel, J17xMT5.50.  This one has the straight spokes, not angled like OEM Yamaha wheel.
Also:
64741-17E00 SPACER,REAR AXLE,R
64751-46E00 SPACER,REAR AXLE,L
I used a 170 x 60 tyre, as I find it is slightly taller than the 180 x 55.  I get about 1cm clearance between chain and tyre.
The 180 x 55 also fits with sufficient clearance.
Bill.
Click for Ron Ayres Fiche
Sold it!
p51bombay
Quote from: billwest on October 05, 2010, 01:12:10 AM
Quote from: wakdady on October 04, 2010, 10:30:20 AM
what exactly was your method? i wanted to do the GSXR wheel swap but now i'm seeing i have to make my own brake rod. Which parts did you use? Your pics help, but the parts used would be nice.
Parts used (all Suzuki):
Rear wheel:  GSXR1100 '92-'94
Rear sprocket:  GSXR750, 40 teeth '92-'94.  This one suits the chain.
Rear caliper, torque arm: GSX750F (Katana) '94
Caliper bracket: GSXR1100W, Part No 69721-46E00
Suzuki spacers: GSXR1100 '92-'94
One extra washer each side.
Tyre:  Mich Pilot Road 2, 170 x 60
Hope this helps.
I know this is an old thread but in regards to the Katana caliper and TA - do you know what range of model years are the same?  Also, someone mentioned that some of the calipers are slightly different, could someone post what I do and do not what prior to looking for one?
p51bombay
Also, does the Katana caliper and bracket need to be a 750 part or can a 600 or 1100 be used and if so what years?
