Speedometer, Turn Signals
Started by roryd, September 28, 2010, 09:27:17 PM
Ok so the speedometer needle bounces around and is all over the place. Occasionally there is a loud whistling sound that comes from the front of the bike, and the self cancelling turn signals do not cancel anymore. Anyone know how to fix one or all of the
roryd21@gmail.com
1 (100%)
np
0 (0%)
Total Members Voted: 0
roryd
Please email me at roryd21@gmail.com if you can answer any of these questions for me, THANKS!!
Loud whistling and a bouncing speedo?  The speedo cable itself is really a super tight and long spring.  Wouldn't be surprised if you could fix things very quickly.... remove the bottom connection of the speedo cable to the speedo drive unit.  Pull the long springy bit out of the cable.  Coat it in your favorite grease (not KY... permatex's shiny silver antiseize is what I use, but a more normal grease would work as well, prolly).  Reassemble.  Shooting WD40 around the wheel bearings and drive and such is all up to you, but it could help a bit.
Possible the speedo itself went bad, but more likely that the cable's sticking a bit at some point, and then it loads and unloads (winds and unwinds... y'know, like a spring, eh?) and that makes things bouncy.
Quote from: andyb on September 30, 2010, 06:44:34 AM
If you remove the cable entirely it'll 'fix' it too.
Just sayin.
:yes:
Maybe... the sender rotates too, so there's a chance the squeak is from that.  The bounce isn't, though.
